Build RTEMS
Sat Mar 9 07:30:49 UTC 2013
Assuming you fixed the typos Ralf spotted, it still
looks like you are configuring 4.10.2 using
the sparc-rtems4.11 target and because of /opt/rtems-4.11
as the --prefix argument probably using the 4.11
tools.
You MUST match the tools and the RTEMS version.
4.11 is NOT the 4.10.2 tarball. 4.11 is the development
head from the git repository.
4.10.2 requires the 4.10 tools and the target should
be sparc-rtems4.10.
If you don't match the versions, this is doomed.
--joel
On 3/9/2013 1:20 AM, Ralf Corsepius wrote:
> On 03/09/2013 07:54 AM, Bucher Fabio wrote:
>> Ah sorry, yes I use 4.10.2 and the 4.11 tools.
>> The command fromthe getting Startet (not the wiki):
>>       ../rtems-4.10.2/configure --target=sparc-rtems4.11 \
>>       --disable-posix --disable-networking --disable-cxx \
>>       --enable-rtemsbsp=sis \
>>       --prefix=/opt/rtems-4.11
>> Warnings:
>> 1.) you should use --buils, --host, -target
>> 2.) invalid host type: --disable-posix
>> Configure error:
>> invalid variable name: `--enable-rtemsbsp`
> All these indicate a typo somewhere on your call to configure.
>> The command from the getting startet wiki page:
>>       ../rtems-4.10.2/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis \
>>       --enable-test=samples \
>>       --disable posix \
>> Configure error:
>> invalid variable name: ` --enable-tests`
>> If I dont use --enable tests, the error is: invalid variable name: `prefix`
> Could you please retry and resend this report?
> There are too many typos in your mail above to be able to help, in
> particular, because the cause of your issue is likely typos.
> E.g. "--disable posix" (This should be --disable-posix)
> Ralf
> rtems-users mailing list
> rtems-users at rtems.org
