Filesystem mounting/layout
Matthew J Fletcher
amimjf at gmail.com
Mon Mar 11 10:48:48 UTC 2013
Hi,
Looking in the fileio sample it looks pretty simple to register a IMFS
device, but could i have some guidance on how best to setup an IMFS root,
IMFS store on SRAM and a RFS store on NOR Flash.
Is it possible/sensible to use an IMFS filesystem as both a root filesystem
and also as storage filesystem as you would on linux ?
e.g IMFS would provide
/etc
/sram <- which is a 256k block
/flash <- which is a mounted RFS 4M block of NOR
Registering the IMFS device driver looks simple enough, but when it comes
to mounting and formating both IMFS and RFS i am slightly confused.
The RFS wiki entry shows using rtems_rtfs_format() and the standard mount()
call with a rtems_filesystem_mount_table_entry structure. But the fileio
sample shows using rtems_fsmount() passing in an fstab_t structure.
Also is RFS support a configure time option that i need to have enable
previously ?
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130311/2c1554be/attachment.html>
