building RTEMS
Bucher Fabio
fabio.bucher at ntb.ch
Tue Mar 12 00:50:09 UTC 2013
Hi
I hope you are not to unnerved because of me. I took the toolset 4.10 and installed them, so it created a directory /opt/rtems-4.10.
The next step is to untar the RTEMS Source (rtems-4.10.2.tar.bz2). Now I am a little confused, because in the getting startet on-line library it said: "unpack the rtems source into the tools directory", but there is no such directory. So i unpacked it into /opt.
Now I have a rtems-4.10 and a rtems-4.10.2 directory in /opt.
Then I did: export PATH=/opt/rtems-4.10/bin:$PATH
I can run the test programm in the terminal: sparc-rtems-gcc -v S f.c and the other one too, it works.
Now I followed the next step: : ./bootstrap (in the rtems-4.10.2 directory), it didnt work (Error Message: couldnt find the commando aclocal, automake and autoconf).
In a new directory (build-rtems): ../rtems-4.10.2/configure --target=sparc-rtems4.10 --enable-rtemsbsp=sis --enable-tests=samples --disable-posix [options from the quick start]
gave me the error message:
checking for gmake... gmake
checking for RTEMS Version... 4.10.2
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... sparc-unknown-rtems4.10
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether gmake sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /bin/sh '../../../rtems-4.10.2/tools/build/configure' '--prefix=/opt/rtems-4.10' '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu' '--enable-rtemsbsp=sis' '--enable-tests=samples' '--disable-posix' '--target=sparc-rtems4.10' '--cache-file=/dev/null' '--srcdir=../../../rtems-4.10.2/tools/build'
checking for i686-pc-linux-gnu-gcc... no
checking for gcc... no
checking for i686-pc-linux-gnu-cc... no
checking for cc... no
checking for i686-pc-linux-gnu-cl.exe... no
checking for cl.exe... no
configure: error: in `/opt/b-sis/tools/build':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
configure: error: /bin/sh '../../../rtems-4.10.2/tools/build/configure' failed for tools/build
Where in this process is my mistake?
Thank you for your help.
