flashdisk erase before registering driver
Matthew J Fletcher
amimjf at gmail.com
Thu Mar 14 16:03:34 UTC 2013
Hi,
The blank check code in am29lv160, called from rtems_disk_inititialize
tests if a read of flash is not 0xff, the only way to set flash to that
state is to erase the sector, but I don't see how rtems can do that before
rtems_disk_initialize has not finished yet.
I am confused why flashdisk is marking the segment as failed in
rtems_fdisk_recover_block_mappings but its not attempting to call
rtems_fdisk_seg_erase.
On 14 Mar 2013 14:36, "Sebastian Huber" <sebastian.huber at embedded-brains.de>
wrote:
> On 03/14/2013 02:49 PM, Matthew J Fletcher wrote:
>> But if the flash is not all erased how can rtems erase it before the
>> flashdisk
>> driver is registered ? i see there is an ioctrl() to erase the disk but i
>> guess
>> that wont work prior to the flashdisk being registered.
> So you want to erase the disk whenever you start RTEMS?
> You can only use the driver after its initialization.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20130314/af6f2292/attachment.html>
