Contact - RTEMS tests
Gustavo Luiz Pasqualini
pasqualini.gustavo at gmail.com
Thu Mar 14 18:19:47 UTC 2013
Hello,
I am a student of Masters in Mechatronics by IFSC (Federal Institute of Science and Technology).
My research includes testing different RTOS (hard and soft)
The ideia is to load(port) in the same hardware these compatibles RTOS. The plataform is the Kit Luminary lm3s8962(Stellaris Arm Cortex - Texas) and after make the tests.
Do you have any material / documentation / articles / monographies about RTOS for i attach in my work?
I need help to prepare the documentation of this work!
Best Regards
About the Tests:
My idea is to load this RTOS in the Kit Luminary lm3s8962(Stellaris Arm Cortex - Texas) and make a lot of tests.
The tests include a lot of things how to verify the latency of a RTOS, how much non deterministic a RTOS is, control a servo motor and simultaneously make calls for get the status of the interfaces of the kit and verify if the time of these processes(threads) are served, execute simultaneously processes and verify the scheduler of the RTOS selecting the process by priorities, allocate memory(instances of objects) and verify the velocity of this job, etc.
I will consider the same activity for different RTOSes!
My research is public!!
Thanks!!
Gustavo Pasqualini
URL: <http://lists.rtems.org/pipermail/users/attachments/20130314/603a4f28/attachment.html>
