FW: Rtems 4.9: Error: Requires: libgmp.so.3()(64bit)
Puneet puneetar at buffalo.edu
Fri Mar 15 23:45:47 UTC 2013
Hi All,
I am installing rtems-4.9 on fedora 18. (require it for an application only
compatiable with 4.9.3 version)
I want to configure it for SPARC architecture, but while installing sparc
specific tootset it is giving the following ERROR:
[puneet at localhost ~]$ sudo yum install rtems-4.9-sparc-*
Loaded plugins: langpacks, presto
Package rtems-4.9-sparc-rtems4.9-gcc-libgcc-4.3.2-25.el6.noarch already
installed and latest version
Package rtems-4.9-sparc-rtems4.9-gdb-6.8-11.el6.x86_64 already installed and
latest version
Package rtems-4.9-sparc-rtems4.9-newlib-1.16.0-25.el6.noarch already
Package rtems-4.9-sparc-rtems4.9-binutils-2.19-3.el6.x86_64 already
Package rtems-4.9-sparc-rtems4.9-gcc-libstdc++-4.3.2-25.el6.noarch already
Resolving Dependencies
--> Running transaction check
---> Package rtems-4.9-sparc-rtems4.9-gcc.x86_64 0:4.3.2-25.el6 will be
installed
--> Processing Dependency: rtems-4.9-gcc-common for package:
rtems-4.9-sparc-rtems4.9-gcc-4.3.2-25.el6.x86_64
--> Processing Dependency: libgmp.so.3()(64bit) for package:
--> Processing Dependency: libmpfr.so.1()(64bit) for package:
---> Package rtems-4.9-sparc-rtems4.9-gcc-c++.x86_64 0:4.3.2-25.el6 will be
installed
rtems-4.9-sparc-rtems4.9-gcc-c++-4.3.2-25.el6.x86_64
---> Package rtems-4.9-gcc-common.noarch 0:4.3.2-25.el6 will be installed
installed
installed
--> Finished Dependency Resolution
Error: Package: rtems-4.9-sparc-rtems4.9-gcc-c++-4.3.2-25.el6.x86_64
(rtems-4.9)
Error: Package: rtems-4.9-sparc-rtems4.9-gcc-4.3.2-25.el6.x86_64 (rtems-4.9)
           Requires: libmpfr.so.1()(64bit)
(rtems-4.9)
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
**I have already installed "gmp, gmp-devel 5.0.5-3.fc18" also "mpfr,
mpfr-devel 3.1.1-1.fc18" which i think contain the required packages, but
still it is giving this error.
Kindly, inform what I am missing ?
Thanks
Puneet
URL: <http://lists.rtems.org/pipermail/users/attachments/20130315/02b30370/attachment.html>
