Rtems 4.9: Error: Requires: libgmp.so.3()(64bit)
Joel Sherrill
Joel.Sherrill at OARcorp.com
Sat Mar 16 13:48:17 UTC 2013
Ralf your perspective is from that of a tool packager. It may no longer be of interest to you and not worth your trouble but it isn't dead. This is a case where building one's own tools from source is a viable option.
There may be future 4.9 releases. But the number of hosts with prebuilt tools is in decline.
--joel
Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
On 03/16/2013 12:45 AM, Puneet wrote:
> Hi All,
> I am installing rtems-4.9 on fedora 18. (require it for an application
> only compatiable with 4.9.3 version)
> I want to configure it for SPARC architecture, but while installing
> sparc specific tootset it is giving the following ERROR:
> [puneet at localhost ~]$ sudo yum install rtems-4.9-sparc-*
> Loaded plugins: langpacks, presto
> Package rtems-4.9-sparc-rtems4.9-gcc-libgcc-4.3.2-25.el6.noarch already
> installed and latest version
> Package rtems-4.9-sparc-rtems4.9-gdb-6.8-11.el6.x86_64 already installed
> and latest version
> Package rtems-4.9-sparc-rtems4.9-newlib-1.16.0-25.el6.noarch already
> Package rtems-4.9-sparc-rtems4.9-binutils-2.19-3.el6.x86_64 already
> Package rtems-4.9-sparc-rtems4.9-gcc-libstdc++-4.3.2-25.el6.noarch
> already installed and latest version
> Resolving Dependencies
> --> Running transaction check
> ---> Package rtems-4.9-sparc-rtems4.9-gcc.x86_64 0:4.3.2-25.el6 will be
> installed
> --> Processing Dependency: rtems-4.9-gcc-common for package:
> rtems-4.9-sparc-rtems4.9-gcc-4.3.2-25.el6.x86_64
> --> Processing Dependency: libgmp.so.3()(64bit) for package:
> --> Processing Dependency: libmpfr.so.1()(64bit) for package:
> ---> Package rtems-4.9-sparc-rtems4.9-gcc-c++.x86_64 0:4.3.2-25.el6 will
> be installed
> rtems-4.9-sparc-rtems4.9-gcc-c++-4.3.2-25.el6.x86_64
> ---> Package rtems-4.9-gcc-common.noarch 0:4.3.2-25.el6 will be installed
> installed
> be installed
> --> Finished Dependency Resolution
> *Error: Package: rtems-4.9-sparc-rtems4.9-gcc-c++-4.3.2-25.el6.x86_64
> (rtems-4.9)
> Error: Package: rtems-4.9-sparc-rtems4.9-gcc-4.3.2-25.el6.x86_64 (rtems-4.9)
> Requires: libmpfr.so.1()(64bit)
> (rtems-4.9)
> Requires: libgmp.so.3()(64bit)*
> You could try using --skip-broken to work around the problem
> You could try running: rpm -Va --nofiles --nodigest
> **I have already installed "gmp, gmp-devel 5.0.5-3.fc18" also "mpfr,
> mpfr-devel 3.1.1-1.fc18" which i think contain the required packages,
> but still it is giving this error.
> Kindly, inform what I am missing ?
Nothing. There are no natively Fedora-18-built rtems-4.9 toolchains
packages. I.e. the rtems-4.9/Fedora-18 combination actually is unsupported.
Instead, as an attempt to provide legacy packages, 4.9/fedora/18 is
redirected to CentOS6 packages. Unfortunately, this attempt has failed,
because CentOS6 and Fedora18 have diverged too much and become incompatible.
Openly said, this kind of issues is another background for my "4.8/4.9
CentOS6 RFC", because the solution to your issue would either be to
provide natively built the packages for the distros currently in "legacy
mode" (All Fedoras, openSUSE and mingw32-w64) or to formally announce
rtems4.9 "dead/abandoned/don't use".
IMO, the facts speak for themselves, and even if this isn't what some
people around here want to accept: RTEMS-4.9 is dead for years.
Ralf
rtems-users mailing list
rtems-users at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-users
