Library files for httpd and shttpd
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Mar 26 14:11:15 UTC 2013
On 3/26/2013 3:07 AM, Ahmed Patel wrote:
> Hi,
> I understand that the functions available in the cpukit\httpd and the
> cpukit\shttpd will be available in the libhttpd.a and the libshttpd.a
> library files. But when i build RTEMS, these files are not generated.
> Is something special needs to be configured to generate these files or
> there is some different library file for the httpd and the shttpd
> webservers?
> I use RTEMS4.10.2 distribution.
Did you build with --enable-networking?
How did you configure?
FWIW we have been through 3 web servers in the project history:
+ GoAhead - replaced as project dried up. GoAhead was bought
by Oracle after we dropped this and that was likely the final nail.
+ Simple HTTPD - became Mongoose
+ Mongoose HTTPD - current webserver solution
Mongoose is an active project and we periodically import a new
version.
> Thanks and Regards.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130326/325b5ee3/attachment.html>
