Whats allowed in the Init() task
Fri Mar 1 15:41:13 UTC 2013
On 03/01/2013 03:07 PM, Matthew J Fletcher wrote:
> Do rtems applications normally create a new task straight away in Init() ? i
> ask because i seem to get stuck with no threads being scheduled after the first
> Clock_isr.
The attributes, initial mode, priority, and stack size of the init task can be
configured with defines:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Configuring-a-System-Classic-API-Initialization-Tasks-Table-Configuration.html#Configuring-a-System-Classic-API-Initialization-Tasks-Table-Configuration
> So after boot_card() completes rtems context switches into Init(), there i
> setup my 10ms tick ISR which calls rtems_clock_tick(). But the original thread
> Init() never gets scheduled again after the first call to rtems_clock_tick().
> I've used JTAG to place breakpoints and i can see the code in Init() is not
> being run.
> I can see the ISR is being called and the interrupt acknowledged due to
> breakpoints there.
The default is a non-preemptive init task.  What do you in the init task?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
