flashdisk erase before registering driver
Matthew J Fletcher amimjf at gmail.com
Mon Mar 18 09:26:58 UTC 2013
Hi,
Yes i think i will have to add code to my BSP to erase all flash sectors if
required.
On 15 March 2013 14:10, Sebastian Huber
<sebastian.huber at embedded-brains.de>wrote:
> On 03/14/2013 05:03 PM, Matthew J Fletcher wrote:
>> The blank check code in am29lv160, called from rtems_disk_inititialize
>> tests if
>> a read of flash is not 0xff, the only way to set flash to that state is to
>> erase the sector, but I don't see how rtems can do that before
>> rtems_disk_initialize has not finished yet.
>> I am confused why flashdisk is marking the segment as failed in
>> rtems_fdisk_recover_block_**mappings but its not attempting to call
>> rtems_fdisk_seg_erase.
> I think we need an operation that erases the complete device and
> re-initializes the driver data structures afterward.
> E-Mail  : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130318/9ddaa5a4/attachment-0001.html>
