Errors in PSIM
    Binkowski, Cassio
    cassioiks at gmail.com
    Wed May  1 20:44:04 UTC 2013
The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
I am using psim-gdb testing my own application, it's not an RTEMS example.
I managed to break right on it, and it stops at:
../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
Signature is the following:
the_source=the_source at entry=INTERNAL_ERROR_CORE,
is_internal=is_internal at entry=true,
    the_error=the_error at entry=5)
I have no clue of what it can be. Do you have any idea?
On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>  Where is the file events.c?
> Break at the fault handler printing that.
> Does this happen with any rtems provided examples?
> Are you using the psim or psim-gdb script to run it?
> "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>  Hi everyone,
>  I was just testing my application using PSIM and it is returning the
> following lines, right after starting a Task:
>  *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC ERROR 5*
> *events.c:404: assertion failed - events->time_from_event > 0*
>  Has anybody experienced this before?
>  Thanks.
> Cassio
URL: <http://lists.rtems.org/pipermail/users/attachments/20130501/87153544/attachment.html>
