Errors in PSIM
Binkowski, Cassio
cassioiks at gmail.com
Wed May 1 21:53:53 UTC 2013
Ok.
1) The Init task is already deleting itself after loading the other tasks.
Do I have to do something else?
2) The memory for partitions came from the board data sheet. I based myself
on the addresses mentioned there and followed upon. I was creating the
first one starting at 0x10000 and incrementing from that according to each
partition's size.
Can you help me set these 2 things up? I'm not really sure how to deal with
that memory issue and the internal error as well.
On Wed, May 1, 2013 at 6:18 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
> That address is invalid for psim. Where does the partition memory come from? Here I'd the memory keep for psim
> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/powerpc/psim/startup/linkcmds
> "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
> I'm also getting the following error when I uncomment the function that
> creates 10 partitions to be used by my application:
> *core_find_mapping() - access to unmaped address, attach a default map
> to handle this - addr=0x1000d2c nr_bytes=0x4 processor=0xa8e5000 cia=0x1028c
> Can you please help?
> On Wed, May 1, 2013 at 5:44 PM, Binkowski, Cassio <cassioiks at gmail.com>wrote:
>> The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
>> I am using psim-gdb testing my own application, it's not an RTEMS
>> example.
>> I managed to break right on it, and it stops at:
>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
>> Signature is the following:
>> the_source=the_source at entry=INTERNAL_ERROR_CORE,
>> is_internal=is_internal at entry=true,
>> the_error=the_error at entry=5)
>> I have no clue of what it can be. Do you have any idea?
>> On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>>> Where is the file events.c?
>>> Break at the fault handler printing that.
>>> Does this happen with any rtems provided examples?
>>> Are you using the psim or psim-gdb script to run it?
>>> Hi everyone,
>>> I was just testing my application using PSIM and it is returning the
>>> following lines, right after starting a Task:
>>> *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC ERROR 5*
>>> *events.c:404: assertion failed - events->time_from_event > 0*
>>> Has anybody experienced this before?
>>> Thanks.
>>> Cassio
URL: <http://lists.rtems.org/pipermail/users/attachments/20130501/0758cd16/attachment.html>
