Errors in PSIM
Binkowski, Cassio
cassioiks at gmail.com
Wed May 1 23:03:17 UTC 2013
Hmmm. The 'Testing Task' does not have a while(1) loop and I'm not deleting
it. Could that be it? *<- Yup, that's it. Just tested. Can you please
explain how did you arrive at this conclusion?*
I'm referring to the MPC5200B board. You can see the manual in the
following link:
http://www.freescale.com/files/32bit/doc/ref_manual/MPC5200BUM.pdf
Now, mentioning the partitions and memory addresses. I'm not quite sure if
I'm incrementing addresses correctly. I do want to create a partition right
next where the other one finishes.
So, if starting address is 0x10000, the next partition will start at
0x10000 + previousPartitionSize.
Does this make sense?
Thanks.
On Wed, May 1, 2013 at 7:49 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
> It could be another task exiting. You mentioned loading code.
> Psim is a specific simulated hardware environment and does not as configured match any board. If you got addresses from a piece of real hardware, the addresses will not match. What target board's manual are you reading?
> "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
> Ok.
> 1) The Init task is already deleting itself after loading the other
> tasks. Do I have to do something else?
> 2) The memory for partitions came from the board data sheet. I based
> myself on the addresses mentioned there and followed upon. I was creating
> the first one starting at 0x10000 and incrementing from that according to
> each partition's size.
> Can you help me set these 2 things up? I'm not really sure how to deal
> with that memory issue and the internal error as well.
> On Wed, May 1, 2013 at 6:18 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>> That address is invalid for psim. Where does the partition memory come from? Here I'd the memory keep for psim
>> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/powerpc/psim/startup/linkcmds
>> I'm also getting the following error when I uncomment the function that
>> creates 10 partitions to be used by my application:
>> *core_find_mapping() - access to unmaped address, attach a default map
>> to handle this - addr=0x1000d2c nr_bytes=0x4 processor=0xa8e5000 cia=0x1028c
>> Can you please help?
>> On Wed, May 1, 2013 at 5:44 PM, Binkowski, Cassio <cassioiks at gmail.com>wrote:
>>> The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
>>> I am using psim-gdb testing my own application, it's not an RTEMS
>>> example.
>>> I managed to break right on it, and it stops at:
>>> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
>>> Signature is the following:
>>> the_source=the_source at entry=INTERNAL_ERROR_CORE,
>>> is_internal=is_internal at entry=true,
>>> the_error=the_error at entry=5)
>>> I have no clue of what it can be. Do you have any idea?
>>> On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com
>>> > wrote:
>>>> Where is the file events.c?
>>>> Break at the fault handler printing that.
>>>> Does this happen with any rtems provided examples?
>>>> Are you using the psim or psim-gdb script to run it?
>>>> Hi everyone,
>>>> I was just testing my application using PSIM and it is returning the
>>>> following lines, right after starting a Task:
>>>> *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC ERROR 5*
>>>> *events.c:404: assertion failed - events->time_from_event > 0*
>>>> Has anybody experienced this before?
>>>> Thanks.
>>>> Cassio
URL: <http://lists.rtems.org/pipermail/users/attachments/20130501/f23f306c/attachment.html>
