RTEMS Scheduler Simulator Status Update
Joel Sherrill
joel.sherrill at OARcorp.com
Sun May 5 16:34:47 UTC 2013
Using The Scheduler Simulator is now in AsciiDoc and in the
the rtems-schedsim/schedim directory. It should be easier to
fix and update now.
Chris.. can you provide the asciidoc command that generates
the spiffy rtems source builder page. :)
On 5/5/2013 10:55 AM, Joel Sherrill wrote:
> On 5/5/2013 8:30 AM, wei.a.yang wrote:
>> 在 2013-5-4,22:01,Joel Sherrill <joel.sherrill at oarcorp.com
>> <mailto:joel.sherrill at oarcorp.com>> 写道:
>>> On 5/3/2013 9:18 PM, yangwei weiyang wrote:
>>>> Hi
>>>> When i build the scheduler-sim it encountered some error:
>>>> weiy at WeiY-host:/project/weiy/gsoc2013/rtems-schedsim$ autoconf
>>>> configure.ac:18 <http://configure.ac:18>: error: possibly undefined
>>>> macro: AM_INIT_AUTOMAKE
>>>> If this token and others are legitimate, please use
>>>> m4_pattern_allow.
>>>> See the Autoconf documentation.
>>>> configure.ac:19 <http://configure.ac:19>: error: possibly undefined
>>>> macro: AM_MAINTAINER_MODE
>>> You need to run the bootstrap script found at the top of the main
>>> RTEMS source tree.
>>> rtems-schedsim avoids duplicating files from the main source tree.
>>> Can you build the RTEMS head? rtems-schedsim uses the same version
>>> of autoconf and automake.
>> Thank you Joel, I have built the sim successfully and run all the
>> scenarios. So next step I will look deep into its source code and
>> learn how to write test scenarios.
> Great! I didn't think it was hard to build. :)
> I have attached two Open Office Documents which I wrote when the simulator
> was created. There is a README in rtems-schedsim/schedsim which
> unfortunately
> looked to be corrupted by the cvs->git transition. It should be a
> subset of what
> is in these documents.
> I think I will convert at least the Using document to asciidoc and
> replace the
> README. :)
>>>> Is there any reference about how to configure and build the schedsim.
>>> There is a readme at the top of the source tree.
>>>> 2013/5/2 Joel Sherrill <joel.sherrill at oarcorp.com
>>>> Hi
>>>> I just wanted to pass along that the RTEMS Scheduler
>>>> Simulator is now updated and appears to be working
>>>> great with the current RTEMS source. The git is:
>>>> git://git.rtems.org/rtems-schedsim.git
>>>> <http://git.rtems.org/rtems-schedsim.git>
>>>> I also updated the wiki page:
>>>> http://wiki.rtems.org/wiki/index.php/SuperCore_Scheduler#Scheduler_Simulator
>>>> This should be of use to at least two GSOC proposals.
>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>> Support Available (256) 722-9985
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>>> Wei Yang
>>>> Best Regards
>>>> wei.a.yang at gmail.com <http://gmail.com>
URL: <http://lists.rtems.org/pipermail/users/attachments/20130505/c3e3b8c2/attachment.html>
