RTEMS classic timers
Wed May 15 11:25:51 UTC 2013
Hello,
On 05/15/2013 01:16 PM, Matthew J Fletcher wrote:
> Hi,
> It looks like rtems_timer_fire_after() is a one time only timer, you need to
> call rtems_timer_fire_after() to generate another.
you can use rtems_timer_reset() to restart the timer in the timer service routine.
> The documentation does not seem to indicate that, is it possible a small update
> could be made for clarity.
> I wrongly presumed it was a repeating timer that would go until you cancelled
> the timer.
You can send a patch for the documentation if you want:
http://git.rtems.org/rtems/tree/doc/user/timer.t
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
