RTEMS classic timers
Matthew J Fletcher
amimjf at gmail.com
Wed May 15 21:32:29 UTC 2013
Hi,
Where in the git tree are examples-v2 ?
On 15 May 2013 12:44, Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
> Also simple examples for inclusion in examples-v2 are appreciated.
> Sometimes there is nothing like seeing some working code
> Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> Hello,
> On 05/15/2013 01:16 PM, Matthew J Fletcher wrote:
> > Hi,
> > It looks like rtems_timer_fire_after() is a one time only timer, you
> need to
> > call rtems_timer_fire_after() to generate another.
> you can use rtems_timer_reset() to restart the timer in the timer service
> routine.
> > The documentation does not seem to indicate that, is it possible a small
> update
> > could be made for clarity.
> > I wrongly presumed it was a repeating timer that would go until you
> cancelled
> > the timer.
> You can send a patch for the documentation if you want:
> http://git.rtems.org/rtems/tree/doc/user/timer.t
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> rtems-users mailing list
> rtems-users at rtems.org
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130515/1548c96a/attachment.html>
