Raspberry Pi BSP debugging
Claus, Ric
claus at slac.stanford.edu
Wed May 1 17:11:30 UTC 2013
It's not clear what your debugging environment is like, but if you could put some sort of indicator (e.g. a printk, a write to memory that is persistent across reboots, or turn on an LED) in each of the exception vectors (except IRQ, since it will be tickled often by at least clock), then you could tell whether you've taken an exception. It smells like you're taking an alignment exception and landing in a for (;;) loop.
It'd interesting to know the pros and cons of enabling unaligned accesses with CP15. Naively, it might seem like a good idea to always enable these. Presumably it kills performance to do so, however.
Ric
________________________________________
From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] On Behalf Of Alan Cudmore [alan.cudmore at gmail.com]
Sent: Wednesday, May 01, 2013 8:12 AM
To: Gedare Bloom
Cc: rtems-users at rtems.org
Subject: Re: Raspberry Pi BSP debugging
Great idea. It should be easy enough to try, and it looks like the bit to enable unaligned access is not set in the BSP.
Thanks,
Alan
On Wed, May 1, 2013 at 10:38 AM, Gedare Bloom <gedare at rtems.org<mailto:gedare at rtems.org>> wrote:
Could it be a matter of the compiler (not) knowing the correct
alignment for the target architecture?
To quote Sebastian from a recent post: "Please have a look in the
ARM1176JZF-S manual. You may have to enable the unaligned access in
the CP15."
-Gedare
On Wed, May 1, 2013 at 10:16 AM, Alan Cudmore <alan.cudmore at gmail.com<mailto:alan.cudmore at gmail.com>> wrote:
> I'm trying to track down a bug in the Raspberry Pi BSP. It will be much
> easier once I get a JTAG device, but for now I have been able to narrow down
> one specific instance where the BSP hangs.
> The first symptom of this problem was with a shell example. If I type an
> invalid shell command, I noticed it will hang or crash on the strncat
> function.
> Next, I modified the simple hello world sample and found that it will also
> hang with a strncat call. I copied the strncat function from the newlib
> sources and found that the local copies ( optimized for size and speed )
> work. The attached example shows the two local strncat calls followed by the
> newlib call. It will always hang on the newlib call.
> This example works on the arm920/gdb simulator and the sparc-sis simulator.
> Some other notes;
> - The memory map looks reasonable, comparing it to the arm920 map
> - Many other newlib functions work such as strncpy, printf, etc
> - Much of the other basic RTEMS seem to work as well. I can create a RAM
> disk, format it , mount it, copy files, etc. I ran many of the tests such as
> unlimited, ticker, etc.
> If anyone has an idea I can try let me know. Otherwise I might just wait
> until I can get a JTAG device hooked up.
> Thanks,
> Alan
> rtems-users mailing list
> rtems-users at rtems.org<mailto:rtems-users at rtems.org>
