Errors in PSIM
Binkowski, Cassio
cassioiks at gmail.com
Wed May 1 21:09:01 UTC 2013
I'm also getting the following error when I uncomment the function that
creates 10 partitions to be used by my application:
*core_find_mapping() - access to unmaped address, attach a default map to
handle this - addr=0x1000d2c nr_bytes=0x4 processor=0xa8e5000 cia=0x1028c*
Can you please help?
On Wed, May 1, 2013 at 5:44 PM, Binkowski, Cassio <cassioiks at gmail.com>wrote:
> The file 'events.c' is inside /gdb-7.5.1/sim/ppc.
> I am using psim-gdb testing my own application, it's not an RTEMS example.
> I managed to break right on it, and it stops at:
> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:58
> Signature is the following:
> the_source=the_source at entry=INTERNAL_ERROR_CORE,
> is_internal=is_internal at entry=true,
> the_error=the_error at entry=5)
> I have no clue of what it can be. Do you have any idea?
> On Wed, May 1, 2013 at 5:37 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>> Where is the file events.c?
>> Break at the fault handler printing that.
>> Does this happen with any rtems provided examples?
>> Are you using the psim or psim-gdb script to run it?
>> "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>> Hi everyone,
>> I was just testing my application using PSIM and it is returning the
>> following lines, right after starting a Task:
>> *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC ERROR 5*
>> *events.c:404: assertion failed - events->time_from_event > 0*
>> Has anybody experienced this before?
>> Thanks.
>> Cassio
URL: <http://lists.rtems.org/pipermail/users/attachments/20130501/41db63d4/attachment-0001.html>
