RTEMS Scheduler Simulator Status Update
wei.a.yang wei.a.yang at gmail.com
Sun May 5 13:30:50 UTC 2013
在 2013-5-4,22:01,Joel Sherrill <joel.sherrill at oarcorp.com> 写道:
> On 5/3/2013 9:18 PM, yangwei weiyang wrote:
>> Hi
>> When i build the scheduler-sim it encountered some error:
>> weiy at WeiY-host:/project/weiy/gsoc2013/rtems-schedsim$ autoconf
>> configure.ac:18: error: possibly undefined macro: AM_INIT_AUTOMAKE
>>       If this token and others are legitimate, please use m4_pattern_allow.
>>       See the Autoconf documentation.
>> configure.ac:19: error: possibly undefined macro: AM_MAINTAINER_MODE
> You need to run the bootstrap script found at the top of the main
> RTEMS source tree.
> rtems-schedsim avoids duplicating files from the main source tree.
> Can you build the RTEMS head? rtems-schedsim uses the same version
> of autoconf and automake.
Thank you Joel, I have built the sim successfully and run all the scenarios. So next step I will look deep into its source code and learn how to write test scenarios.
>> Is there any reference about how to configure and build the schedsim.
> There is a readme at the top of the source tree.
>> 2013/5/2 Joel Sherrill <joel.sherrill at oarcorp.com>
>>> Hi
>>> I just wanted to pass along that the RTEMS Scheduler
>>> Simulator is now updated and appears to be working
>>> great with the current RTEMS source. The git is:
>>> git://git.rtems.org/rtems-schedsim.git
>>> I also updated the wiki page:
>>> http://wiki.rtems.org/wiki/index.php/SuperCore_Scheduler#Scheduler_Simulator
>>> This should be of use to at least two GSOC proposals.
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Wei Yang
>> Best Regards
URL: <http://lists.rtems.org/pipermail/users/attachments/20130505/92e78e44/attachment-0001.html>
