bfin simulator problems
Joel Sherrill
joel.sherrill at OARcorp.com
Fri May 10 15:18:49 UTC 2013
On 5/10/2013 9:49 AM, Peng Fan wrote:
> Hi,
> I have encounter a problem when using bfin simulator.
> $bf537Stamp -i ticker.exe
> bfin-rtems4.11-run is /opt/rtems-4.11/bin/bfin-rtems4.11-run
> *** CLOCK TICK TEST ***
> TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
> TA2 - rtems_clock_get_tod - 09:00:00 12/31/1988
> TA3 - rtems_clock_get_tod - 09:00:00 12/31/1988
> It stops at the 'TA3' and does not go on.
> And when I use ezkit533 bsp with the command 'ezkit533 -i hello.exe',
> it shows that:
> "bfin-rtems4.11-run is /opt/rtems-4.11/bin/bfin-rtems4.11-run
> _cec_raise: double fault at 0xffb00000 ! :("
> I have tried skyeye 1.2.4 to run bfin, but some instructions can not
> be decoded.
My skyeye is 1.2.8 but it has been a while since I tested this BSP.
You may not need a clock tick to test RTL.
> Thanks.
> Regards,
> Peng.
