i386-rtems4.11-ranlib: command not found
dave
daveerickson at shaw.ca
Sat Nov 2 03:03:14 UTC 2013
chowned /opt/rtems-4.11 to usr solves problem.
Thanks
Dave
On 11/01/2013 07:15 PM, Gedare Bloom wrote:
> I suspect the issue is root's path, when it executes sh, is not
> picking up the tools. You could chown /opt/rtems-4.11 and just make
> install. I think there are other solutions but I forget offhand.
> -Gedare
> On Nov 1, 2013 4:05 PM, "dave" <daveerickson at shaw.ca
> <mailto:daveerickson at shaw.ca>> wrote:
> i ran into this error 'make install' ing rtems into
> /opt/rtems-4.11 folder. I have permission and the ranlib version
> is available.
> sudo make install ends with error:
> /usr/bin/install -c -m 644 libsapi.a
> '/opt/rtems-4.11/i386-rtems4.11/pc386/lib'
> ( cd '/opt/rtems-4.11/i386-rtems4.11/pc386/lib' &&
> i386-rtems4.11-ranlib libsapi.a )
> /bin/sh: line 5: i386-rtems4.11-ranlib: command not found
> gmake[5]: *** [install-project_libLIBRARIES] Error 127
> gmake[5]: Leaving directory
> `/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386/cpukit/sapi'
> gmake[4]: *** [install-am] Error 2
> gmake[4]: Leaving directory
> gmake[3]: *** [install-recursive] Error 1
> gmake[3]: Leaving directory
> `/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386/cpukit'
> gmake[2]: *** [install-recursive] Error 1
> gmake[2]: Leaving directory
> `/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386'
> gmake[1]: *** [install-recursive] Error 1
> gmake[1]: Leaving directory
> `/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c'
> make: *** [install-recursive] Error 1
> [dave at localhost build-i386]$ man ranlib
> [dave at localhost build-i386]$ ls
> include libsapi.a
> [dave at localhost build-i386]$ which i386-rtems4.11-ranlib
> /opt/rtems-4.11/bin/i386-rtems4.11-ranlib
> is this a configuration error?
> Thanks in advance,
> Dave
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20131101/95b817ac/attachment.html>
