Anyone make a dynamic module system?
Till Straumann
strauman at slac.stanford.edu
Sat Nov 2 16:42:25 UTC 2013
On 11/01/2013 07:34 PM, Dave Erickson wrote:
> Ok thanks i downloaded it and ill check it out. Doers it have a native daemon so I can put it on socket?
I'm not sure I understand the question but I usually spawn cexpsh from
the rtems telnetd
(see attached code).
HTH
- T.
> Cheers!
> Dave
> Sent from my iPad
> On 2013-11-01, at 9:02 AM, Till Straumann <strauman at slac.stanford.edu> wrote:
>> There is also the cexpsh which can dynamically load/link stuff
>> http://www.slac.stanford.edu/~strauman/rtems/cexp/index.html
>> On 10/31/2013 07:28 PM, Dave Erickson wrote:
>>> Hello;
>>> As I embark on developing my next system, I was looking for ways to reduce down time by adding code to a running kernel. For my applications I will have access to larger 686 systems so drive space, memory, etc. is not an issue. I wondered aloud if anyone has made a "kernel module" system for an RTEMS based core system? Dynamically loading code segments to allow for remote system development. What are the pitfalls and advantages this might bring to development?
>>> Thank you for any help,
>>> Sent from my iPhone
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20131102/20bf9eb0/attachment.bin>
