Gaia Update Request
Leonard Bise
leonard.bise at syderal.ch
Mon Nov 11 10:21:31 UTC 2013
Hello,
As it has been said GAIA has been postponed. However I can tell you, having
worked on the PDHU (SDRAM mass memory), that we are indeed using RTEMS as
posted in the pdf linked up there. I think its version 4.6 of RTEMS and
with a LEON2 processor (AT697). Hopefully everything goes fine when it
finally goes on its journey
Best regards,
*Léonard Bise*
Software Design Engineer
Direct Line +41 (0)32 338 9902
*SYDERAL SA*
Neuenburgstrasse 7
CH-3238 Gals (Switzerland)
Desk Line +41 (0)32 338 9800
Web Site http://www.syderal.ch
2013/10/25 Jiri Gaisler <jiri at gaisler.se>
> It could be worth mentioning that the PDMU is based on the
> ERC32 (TSC695) SPARC V7 processor, while the PDHU is using
> a LEON2FT (AT697) SPARC V8 chip. A simple data sheet for the
> PDHU can be found here :
> http://www.syderal.ch/images/allproductsheets/gaia%20pdhu%20product%20syd.pdf
> Jiri.
> On 10/25/2013 09:56 AM, Zandin Johan RUAG wrote:
> > Joel Sherrill wrote:
> >> Any ideas which subsystems run RTEMS?
> > The Gaia CDMU from RUAG Space AB runs RTEMS 4.6.1.
> > I just added this on http://wiki.rtems.org/wiki/index.php/GAIA
> > where I also saw that the PDHU was already mentioned.
> >> FWIW I have wanted to run a launch count down on rtems.org
> >> for each launch that includes some RTEMS based system.
> >> It just seems hard to track them. :(
> > I think this would be a good starting point, at least for the
> > ones reasonably close in time:
> > http://spaceflightnow.com/tracking/
> > /Johan
> > Johan Zandin Computer Engineer
> > RUAG Space AB Phone: +46-31-735 41 47
> > SE-405 15 Gothenburg, Sweden Fax: +46-31-735 40 00
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20131111/c72f8f66/attachment.html>
