Rate Monotonic Tasks
sarraciro sarraciro at yahoo.it
Mon Nov 18 02:09:20 UTC 2013
Hi,
I'm trying to modify the example called classic_api triple_period.
Can I create and run in the same time 2 Rate Monotonic Tasks?
If I try to duplicate the Task2 (the handler for
Rate_Monotonic_Period_Task) of the triple_period example.. changing
name, priority and deadline the task that is called for second stucks
with  this error:
	RM failed with status: 5
Where in documentation are defined the errors in numeric form?
Anyone have idea of my error?
PS: the platform in which I debug is STM32F4-Discovery.
Thanks
Regards
RC
Il giorno dom, 17/11/2013 alle 14.24 -0500, Gedare Bloom ha scritto:
> Congrats :)
> On Sun, Nov 17, 2013 at 6:20 AM, sarraciro <sarraciro at yahoo.it> wrote:
> > Hi,
> > Cheers?... for this type of nonsense?? ... I look a little too
> > much ! :) .. :D .. ;) !
> > My board, in this moment, is an ST-board (an STM32F4-Discovery...  we
> > also the new kit with LCD on board (the STM32F429I-Disco).  But the
> > purpose is move on our board with the same class of processor.
> > For Makefile I made a classic-way version in which I can:
> > - define a system.h with RTEMS configuration macros;
> > - define hardware macros for describe the hardware;
> > - include files that contains function and prototypes (but for now in
> > the same build-directory);
> > - shrink the built firmware to fit in the flash memory (reduce the size
> > of built exe);
> > - clean all built objects;
> > In this moment I suspended the packaging with Autotool
> > (./configure,make)... because I worked to a rudimental-gpio-driver ...
> > (achieved last night... with  success...but with a warning)... and other
> > projects.
> > When I can drive all processor resources I want try again to port the
> > Makefile in Autotool version... in particular way I'm interested to
> > deep-packaging (with subdirs for hw-libs, header and sources) and not
> > shallow-packaging.
> > Regards
> > RC  (popovich)
> > Il giorno dom, 17/11/2013 alle 11.35 +0100, emanuel stiebler ha scritto:
> >> On 2013-11-03 03:03, sarraciro wrote:
> >> > Hi guys,
> >> > I have ported the template that I wanted ! :) !
> >> > I had included also a (very) rudimental driver for flash the LEDs of
> >> > STM32F4-Discovery..
> >> > There are some warning (one I presume.. but it appear several time ..
> >> > casting warning..) .. I'll try to fix it tomorrow...
> >> > Thank again for support ... night!
> >> > RC
> >> Hi RC,
> >> did you use a board from the market, or did you use your own?
> >> I'm just getting my own stm32f4 board in few days, so was enjoying
> >> reading about your success ;-)
> >> Did you continue to work on it?
> >> Cheers,
> >> emanuel
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
