Incomplete backtraces
Jiri Gaisler jiri at gaisler.se
Tue Nov 19 22:29:48 UTC 2013
On 11/15/2013 05:56 AM, Mohammed Khoory wrote:
> Hi,
> I'm not sure if this is really RTEMS-related, but I've been having an
> annoying issue when debugging an RTEMS application with GDB (on real
> hardware). Sometimes, when I pause the debugger, or when there is a segfault
> or something similar, I notice that the stack trace is missing a few
> function calls deep down. I know this is not a stack issue, because I am
> able to step out of a function and the system runs stable otherwise. When I
> step out of a function, the backtrace sometimes becomes complete again. This
> doesn't always happen, it seems to be random and I can't determine what's
> causing it.
> For example, if Init() calls function1(), which calls function2(), which
> calls function3(), and a breakpoint is placed in function3(), then when the
> debugger pauses the program the stack trace only shows function3() and
> function2(), and nothing under that.
> My setup is stock RTEMS 4.10.2, with GDB 7.2 running under MinGW Windows,
> compiled for SPARC LEON3. The tools are prebuilt and obtained from the RTEMS
> website.
You might want to try with gdb-6.4, which is the last version
that work for me. Later gdb versions have changed something in
the SPARC stack unwinding, leading to all sorts of problems ...
Jiri.
> I've been experiencing this issue for a while now, and I've simply worked
> around it, but it's starting to get difficult now. I was hoping that someone
> else in the mailing list has experienced this as well and knows a way around
> it.
> Thanks,
> Mohammed Khoory
> rtems-users mailing list
> rtems-users at rtems.org
