Anyone make a dynamic module system?
Dave Erickson
daveerickson at shaw.ca
Sat Nov 2 02:34:58 UTC 2013
Ok thanks i downloaded it and ill check it out. Doers it have a native daemon so I can put it on socket?
Cheers!
Dave
Sent from my iPad
On 2013-11-01, at 9:02 AM, Till Straumann <strauman at slac.stanford.edu> wrote:
> There is also the cexpsh which can dynamically load/link stuff
> http://www.slac.stanford.edu/~strauman/rtems/cexp/index.html
> On 10/31/2013 07:28 PM, Dave Erickson wrote:
>> Hello;
>> As I embark on developing my next system, I was looking for ways to reduce down time by adding code to a running kernel. For my applications I will have access to larger 686 systems so drive space, memory, etc. is not an issue. I wondered aloud if anyone has made a "kernel module" system for an RTEMS based core system? Dynamically loading code segments to allow for remote system development. What are the pitfalls and advantages this might bring to development?
>> Thank you for any help,
>> Sent from my iPhone
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
