strange ip_reass issue on powerpc board, need help
Nick Withers
nick.withers at anu.edu.au
Mon Nov 4 23:34:15 UTC 2013
On Fri, 2013-11-01 at 08:33 +0800, Rui Zhengxin wrote:
> On Friday, November 01, 2013 6:47 AM Nick Withers wrote:
> Thanks Nick,
> > On Thu, 2013-10-31 at 17:16 +0800, Rui Zhengxin wrote:
> >> Hi all,
> > Hey Rui,
> >> My board is MPC8309SOM, the uec network adapter driver is port from 8313 tsec, it works well.
> > MVME3100 here, with the MPC8540 and a tsec.
> >> Now I meet a strange ip_reass issue, it cause a crash.
> >> The condition is send a fragment packet with a non-zero ip_offset value but not set IP_MF flag.
> > Is that legal in the first place? You're talking about the "More
> > Fragments" flag, yeah? Shouldn't that *always* be set for packets in a
> > fragmented datagram?
> > 'Course if it ain't legal one still doesn't want to target to crash :-P
> >> It's very easy to make the fragment packet by ping the target board 65000 bytes after clearing PC's ARP table first.
> > What does clearing the ARP table here accomplish?
> Sorry, I forgot to tell you, my PC is Windows XP,
> I find that in Windows XP, if clear ARP table first, then send a big ip packet, the first fragment of is abnormal.
> It's just the last fragment, as I said "a non-zero ip_offset value but not set IP_MF flag".
> The attached is the capture result of wireshark, the third packet is the abnormal fragment.
That looks like the last fragment of a datagram (and hence there aren't
"More Fragments"), so makes sense, I reckon. Compare it to packet #47
(not the reassembly shown against #47 in Wireshark, but the actual
fragment itself), for instance (the last fragment of the first complete
ping datagram).
> > In any event, I haven't been able to crash mine, running RTEMS 4.11 from
> > the start of October.
> >> I trace the code, after call ip_reass, the mbuf chain may become not correct(ps: not everytime), the last mbuf's m_next pointer
> >> not set to NULL. When the upper layer discard the fragment by calling m_freem, the invalid ext_free function pointer cause crash.
> >> I don't know the reason why the mbuf chain is changed.
> >> If you have MPC8313 or other powerpc board, can you help me verify the issue? Very tks for you help.
> > Any other thoughts? My pings're of the form "sudo ping -s 65000 -i 0.25"
> > from a FreeBSD 9.2-STABLE host and aren't actually being responded to
> > above 25152 B of data.
> I test on QEMU run i386 image, the issue not appear.
> If send such an abnormal fragment, the "netstats -mp" command shows the MBUF ftable counter increased,
> then after some time(ttl timeout), the IP Statistics of fragments timed out counter increased.
Which seems fair, doesn't it, on the RTEMS side at least (not so much
the crashing), assuming it hasn't seen all fragments of a datagram?
Are you perhaps dumping and refreshing your ARP cache *while* doing
pings, interrupting one of 'em?
So this is a driver you've ported over, isn't it? Could it be that the
hardware you've ported it to doesn't support Large Receive Offload but
the original hardware did... Or something?
> > I've also got pretty big mbuf (2 MiB) / mbuf cluster (4 MiB) buffers
> > configured, perhaps that's something to do with it?
> >> Thanks & Best regards,
> >> Rui Zhengxin
> > Hope that helps... It probably doesn't! :-(
> Rui Zhengxin
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
