LEON3 Multiprocessor support
Gedare Bloom
gedare at rtems.org
Tue Nov 19 17:19:11 UTC 2013
On Tue, Nov 19, 2013 at 6:06 AM, Sebastian Huber
> On 2013-11-19 11:56, Leonard Bise wrote:
>> Am I correct in thinking that this section of the RTEMS doc :
>> http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Multiprocessing-Manager.html#Multiprocessing-Manager
>> Talks about what I want or is that something else entirely? I'm a bit loss
>> with
>> your comment about multiprocessing support in RTEMS Sebastian.
> RTEMS_MULTIPROCESSING:
> Independent single-processor RTEMS instances share global objects. State
> changes are exchanged by means of message passing.
Typical use for RTEMS_MULTIPROCESSING would be when attaching multiple
processors across a bus. You would reasonably use this option when the
communication between processors is on par with memory access, or
slower than accessing memory.
> RTEMS_SMP:
> One symmetric multi-processor RTEMS instance runs on multiple processors.
Use RTEMS_SMP when the communication between processors can be faster
than memory access, for example in a chip multicore.
If you're investigating RTEMS for a dual core, you'll probably want
the RTEMS_SMP if you can handle waiting for / helping production
quality to come
-Gedare
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> rtems-users mailing list
> rtems-users at rtems.org
