Building rtems-4.11
Joel Sherrill
joel.sherrill at OARcorp.com
Sat Nov 23 01:33:35 UTC 2013
On 11/22/2013 6:33 PM, Kev Fei wrote:
> Hello,
> I am trying to build rtems 4.11 on Linux Mint 13 LTS 64-bit for sparc as
> part of Google Code-In.
Thanks for posting this to the users list. :)
> I used the RTEMS Source Builder to build these tools and I think I have
> them installed correctly:
What command did you use with the RSB? I would have expected
to see the right autoconf and automake versions in this
directory.
More below.
> ls /opt/rtems-4.11/bin
> cklength sparc-rtems4.11-gcov
> eolstrip sparc-rtems4.11-gdb
> install-if-change sparc-rtems4.11-gprof
> packhex sparc-rtems4.11-ld
> rtems-bin2c sparc-rtems4.11-ld.bfd
> sparc-rtems4.11-addr2line sparc-rtems4.11-nm
> sparc-rtems4.11-ar sparc-rtems4.11-objcopy
> sparc-rtems4.11-as sparc-rtems4.11-objdump
> sparc-rtems4.11-c++ sparc-rtems4.11-ranlib
> sparc-rtems4.11-c++filt sparc-rtems4.11-readelf
> sparc-rtems4.11-cpp sparc-rtems4.11-run
> sparc-rtems4.11-difftest sparc-rtems4.11-sis
> sparc-rtems4.11-elfedit sparc-rtems4.11-size
> sparc-rtems4.11-g++ sparc-rtems4.11-sorttimes
> sparc-rtems4.11-gcc-4.8.1 sparc-rtems4.11-strings
> sparc-rtems4.11-gcc-ar sparc-rtems4.11-strip
> sparc-rtems4.11-gcc-nm unhex
> sparc-rtems4.11-gcc-ranlib xmlwf
> Now I'm trying to build rtems, following the Quick Start.
> In $HOME/GCIdevelopment/rtems,
> *Terminal:
> git clone git://git.rtems.org/rtems.git
> <http://git.rtems.org/rtems.git> rtems
> cd rtems
> export PATH=/opt/rtems-4.11/bin:$PATH
> ./bootstrap
Try these steps and let's see what we get.
type sparc-rtems4.11-gcc
Then compile this program ..put it in joel.c
int main() {return 0;}
sparc-rtems4.11-gcc joel.c
What's the output? It should compile just fine.
> First I had to update automake and autoconf. rtems required versions
> higher than what the repositories had, so I had to google them and
> install them from source, which was easy enough.
The RSB handles autoconf/automake as part of the RTEMS tools
if invoked correctly so I am a bit confused. We need the command
as shown above but if you did this much right, they should be
in your PATH.. so
autoconf --version
automake --version
> ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
> --enable-tests=samples --disable-posix
> make
> And I get:
> configure: error: no acceptable cc found in $PATH
> Although sparc-rtems4.11-gcc-4.8.1 is already in
> rtems/b-sis/sparc-rtems4.11, I copy the other tools gcc-ar, gcc-nm, and
> gcc-ranlib too.
This doesn't sound like something you should have done.
> I try the above two commands again and it still doesn't work.
> Output:
> Making all in tools/build
> make[1]: Entering directory
> `/home/kevin/GCIdevelopment/rtems/b-sis/tools/build'
> make all-am
> make[2]: Entering directory
> make[2]: Leaving directory
> make[1]: Leaving directory
> Making all in tools/cpu
> `/home/kevin/GCIdevelopment/rtems/b-sis/tools/cpu'
> Making all in generic
> `/home/kevin/GCIdevelopment/rtems/b-sis/tools/cpu/generic'
> make[2]: Nothing to be done for `all'.
> make[2]: Nothing to be done for `all-am'.
> Making all in testsuites/tools
> `/home/kevin/GCIdevelopment/rtems/b-sis/testsuites/tools'
> `/home/kevin/GCIdevelopment/rtems/b-sis/testsuites/tools/generic'
> Making all in sparc-rtems4.11/c
> `/home/kevin/GCIdevelopment/rtems/b-sis/sparc-rtems4.11/c'
> Making all in .
> Making all in sis
> `/home/kevin/GCIdevelopment/rtems/b-sis/sparc-rtems4.11/c/sis'
> make[2]: *** No rule to make target `all'. Stop.
> make[1]: *** [all-recursive] Error 1
> make: *** [all-recursive] Error 1
> I have tried --enable-posix instead as well as removing the posix tag
> altogether. Google searches for ***No rule to make target 'all'. errors
> have not been very helpful.
> Does anybody have any ideas on what's going on? Thank you!
Try the above and post the results. I think RSB was invoked
with something minor wrong.
> Kevin Fei
