Building rtems-4.11
Alan Cudmore alan.cudmore at gmail.com
Sat Nov 23 03:27:34 UTC 2013
Hi,
Now, Typing "sparc-rtems4.11-gcc" doesn't work :(
If I go to $HOME/GCIdevelopment/rtems/4.11/bin and do
./sparc-rtems4.11-gcc joel.c, it gives me an error.
    /home/kevin/GCIdevelopment/rtems/4.11/lib/gcc/sparc-rtems4.11/4.8.1/../../../../sparc-rtems4.11/bin/ld:
    warning: cannot find entry symbol _start; defaulting to 0000000000010074
For this, try  ./sparc-rtems4.11-gcc -c joel.c
It looks like the compiler is working and is trying to link an executable.
On your first problem:
And I get:
 >     configure: error: no acceptable cc found in $PATH
Do you have the native linux GCC tools installed?
try:
$ gcc -v
and see what it returns.
Hope this helps,
Alan
On 11/22/2013 10:14 PM, Kev Fei wrote:
> RTEMS Source Builder for Tools
> *Terminal:
>     cd
>     mkdir -p GCIdevelopment/rtems/src
>     cd GCIdevelopment/rtems/src
>     git clone git://git.rtems.org/rtems-source-builder.git
>     <http://git.rtems.org/rtems-source-builder.git>
>     cd rtems-source-builder
> --Environment checking
>     source-builder/sb-check
> This turned up for me some
>     warning: exe: absolute exe found in path: (__bzip2) /usr/bin/bzip2
>     warning: exe: absolute exe found in path: (__chgrp) /usr/bin/chgrp
>     warning: exe: absolute exe found in path: (__chown) /usr/sbin/chown
>     warning: exe: absolute exe found in path: (__grep) /usr/bin/grep
>     warning: exe: absolute exe found in path: (__sed) /usr/bin/sed
> These programs were installed. For example, I could run grep in
> terminal. However I had to find the programs from the other locations
> on the disk (/usr/bin or /bin or /lib) and copy them over for the next
> step to work.
> Then it says my environment is ok.
> *Terminal:
>     cd rtems
>     ../source-builder/sb-set-builder --log=l-sparc.txt
>     --prefix=$HOME/GCIdevelopment/rtems/4.11 4.11/rtems-sparc
> This step takes a long time; it took me 46 minutes with downloading.
> Then it ended with an error. It said it could not find python 2.7, but
> I had it installed. After googling, it turned out I had to have
> python2.7-dev installed.
> Finally it built in around 27 minutes.
> *Terminal:
>     ls $HOME/GCIdevelopment/rtems/4.11
>     ls $HOME/GCIdevelopment/rtems/4.11/bin
> Both turned up nice results.
> After reading your comments, I realized I had somehow skipped over
> this step in a newbie mistake :P
>     --prefix=$HOME/GCIdevelopment/rtems/4.11 --bset-tar-file
>     4.11/rtems-sparc
> Built in 29 minutes.
>     0000000000010074
> I think I might've copied over a bunch of the built tools from the
> 4.11/bin to the /opt/rtems-4.11/bin folder at one point.
> Maybe I should just start this thing over sometime :P
> Kevin Fei
> On Fri, Nov 22, 2013 at 10:11 PM, Kev Fei <kev1fei at gmail.com
>     *Terminal:
>         cd
>         /usr/sbin/chown
>     locations on the disk (/usr/bin or /bin or /lib) and copy them
>     over for the next step to work.
>     *Terminal:
>         cd rtems
>     downloading. Then it ended with an error. It said it could not
>     find python 2.7, but I had it installed. After googling, it turned
>     out I had to have python2.7-dev installed.
>     *Terminal:
>         4.11/rtems-sparc
>         0000000000010074
>     Kevin Fei
>     On Fri, Nov 22, 2013 at 8:33 PM, Joel Sherrill
>     <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>         On 11/22/2013 6:33 PM, Kev Fei wrote:
>         > Hello,
>         > I am trying to build rtems 4.11 on Linux Mint 13 LTS 64-bit
>         for sparc as
>         > part of Google Code-In.
>         Thanks for posting this to the users list. :)
>         > I used the RTEMS Source Builder to build these tools and I
>         think I have
>         > them installed correctly:
>         What command did you use with the RSB? I would have expected
>         to see the right autoconf and automake versions in this
>         directory.
>         More below.
>         >     ls /opt/rtems-4.11/bin
>         >     cklength  sparc-rtems4.11-gcov
>         >     eolstrip  sparc-rtems4.11-gdb
>         >     install-if-change sparc-rtems4.11-gprof
>         >     packhex sparc-rtems4.11-ld
>         >     rtems-bin2c sparc-rtems4.11-ld.bfd
>         >     sparc-rtems4.11-addr2line sparc-rtems4.11-nm
>         >     sparc-rtems4.11-ar  sparc-rtems4.11-objcopy
>         >     sparc-rtems4.11-as  sparc-rtems4.11-objdump
>         >     sparc-rtems4.11-c++ sparc-rtems4.11-ranlib
>         >     sparc-rtems4.11-c++filt sparc-rtems4.11-readelf
>         >     sparc-rtems4.11-cpp sparc-rtems4.11-run
>         >     sparc-rtems4.11-difftest  sparc-rtems4.11-sis
>         >     sparc-rtems4.11-elfedit sparc-rtems4.11-size
>         >     sparc-rtems4.11-g++ sparc-rtems4.11-sorttimes
>         >     sparc-rtems4.11-gcc-4.8.1 sparc-rtems4.11-strings
>         >     sparc-rtems4.11-gcc-ar  sparc-rtems4.11-strip
>         >     sparc-rtems4.11-gcc-nm      unhex
>         >     sparc-rtems4.11-gcc-ranlib  xmlwf
>         > Now I'm trying to build rtems, following the Quick Start.
>         > In $HOME/GCIdevelopment/rtems,
>         > *Terminal:
>         >     git clone git://git.rtems.org/rtems.git
>         <http://git.rtems.org/rtems.git>
>         >     <http://git.rtems.org/rtems.git> rtems
>         >     cd rtems
>         >     export PATH=/opt/rtems-4.11/bin:$PATH
>         >     ./bootstrap
>         Try these steps and let's see what we get.
>         type sparc-rtems4.11-gcc
>         Then compile this program ..put it in joel.c
>         int main() {return 0;}
>         What's the output? It should compile just fine.
>         > First I had to update automake and autoconf. rtems required
>         versions
>         > higher than what the repositories had, so I had to google
>         them and
>         > install them from source, which was easy enough.
>         The RSB handles autoconf/automake as part of the RTEMS tools
>         if invoked correctly so I am a bit confused. We need the command
>         as shown above but if you did this much right, they should be
>         in your PATH.. so
>         autoconf --version
>         automake --version
>         >     ../rtems/configure --target=sparc-rtems4.11
>         --enable-rtemsbsp=sis
>         >     --enable-tests=samples --disable-posix
>         >     make
>         > And I get:
>         > Although sparc-rtems4.11-gcc-4.8.1 is already in
>         > rtems/b-sis/sparc-rtems4.11, I copy the other tools gcc-ar,
>         gcc-nm, and
>         > gcc-ranlib too.
>         This doesn't sound like something you should have done.
>         > I try the above two commands again and it still doesn't work.
>         > Output:
>         >     Making all in tools/build
>         >     make[1]: Entering directory
>         > `/home/kevin/GCIdevelopment/rtems/b-sis/tools/build'
>         >     make  all-am
>         >     make[2]: Entering directory
>         >     make[2]: Leaving directory
>         >     make[1]: Leaving directory
>         >     Making all in tools/cpu
>         > `/home/kevin/GCIdevelopment/rtems/b-sis/tools/cpu'
>         >     Making all in generic
>         > `/home/kevin/GCIdevelopment/rtems/b-sis/tools/cpu/generic'
>         >     make[2]: Nothing to be done for `all'.
>         >     make[2]: Nothing to be done for `all-am'.
>         >     Making all in testsuites/tools
>         > `/home/kevin/GCIdevelopment/rtems/b-sis/testsuites/tools'
>         `/home/kevin/GCIdevelopment/rtems/b-sis/testsuites/tools/generic'
>         >     Making all in sparc-rtems4.11/c
>         > `/home/kevin/GCIdevelopment/rtems/b-sis/sparc-rtems4.11/c'
>         >     Making all in .
>         >     Making all in sis
>         > `/home/kevin/GCIdevelopment/rtems/b-sis/sparc-rtems4.11/c/sis'
>         >     make[2]: *** No rule to make target `all'.  Stop.
>         >     make[1]: *** [all-recursive] Error 1
>         >     make: *** [all-recursive] Error 1
>         > I have tried --enable-posix instead as well as removing the
>         posix tag
>         > altogether. Google searches for ***No rule to make target
>         'all'. errors
>         > have not been very helpful.
>         > Does anybody have any ideas on what's going on? Thank you!
>         Try the above and post the results. I think RSB was invoked
>         with something minor wrong.
>         > Kevin Fei
>         Joel Sherrill, Ph.D.             Director of Research &
>         Development
>         joel.sherrill at OARcorp.com        On-Line Applications Research
>         Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>         Support Available (256) 722-9985 <tel:%28256%29%20722-9985>
>     Physics!
>     Layton!
>     Nintendo!
>     Wikipedia!
> Physics!
> Layton!
> Nintendo!
> Wikipedia!
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20131122/b198445c/attachment-0001.html>
