FLOATING POINT with rtems
Sebastian Huber
Fri Nov 29 13:06:34 UTC 2013
On 2013-11-29 13:57, Luca Cinquepalmi wrote:
> BSP is leon2 and these are my GCC options:
> -specs bsp-specs -qrtems -mcpu=V8
Did you build the BSP with these options? The default options are:
CPU_CFLAGS = -mcpu=cypress -msoft-float
With them there will be no floating point support at all no matter which task
attributes you use.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
