FLOATING POINT with rtems
Luca Cinquepalmi cinquepalmi at planetek.it
Fri Nov 29 15:01:41 UTC 2013
No, I didn't get the tools from Gaisler.
I got it form rtems website. v4.11
Luca
Il 29/11/2013 15:59, Joel Sherrill ha scritto:
> On 11/29/2013 7:35 AM, Luca Cinquepalmi wrote:
>> So what is the reason of my error?
>> NB: it is not a compilation error, but it only occurs when SW is
>> executed on my target HW.
> It is not a compilation error but likely a mismatch in compiler
> flags between the way RTEMS was built (assuming no FPU and
> only soft-float) and the way your application code was built
> (assuming an FPU).
> RTEMS was told there is no FPU and thus the FPU enable bit
> will never be set.
> FWIW you never said whether you got the tools from Aeroflex
> Gaisler (RCC) or not. They tend to build with soft-float as
> I recall.
> --joel
>> Il 29/11/2013 14:23, Sebastian Huber ha scritto:
>>> On 2013-11-29 14:19, Luca Cinquepalmi wrote:
>>>> But -msoft-float is used when you wnat to simulate FP coprocessor. It
>>>> is a SW
>>>> library.
>>>> In my case I have a real FP coprocessor, so I don't need to use it.
>>>> Do you agree?
>>> Yes, and you must compile the BSP without the -msoft-float option,
>>> otherwise there will be no support for hardware floating-point
>>> operations at all.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
