shared library with rtems
Luca Cinquepalmi
cinquepalmi at planetek.it
Tue Oct 1 12:41:12 UTC 2013
Shall I use -B instead of -L option in compiling?
Il 01/10/2013 13:36, Wendell Silva ha scritto:
> Well, it should work...
> Could you, please, post the entire command line? The lower case L
> ('l') sounds very simililar to upper case "i" ('I').
> 2013/10/1 Luca Cinquepalmi <cinquepalmi at planetek.it
> <mailto:cinquepalmi at planetek.it>>
> Yes, sure!
> Il 01/10/2013 13:15, Wendell Silva ha scritto:
>> Is there a file named libtestLib.a in lib_path?
>> Hi all,
>> I'm trying to compile a shared library with sparc-rtems-gcc,
>> by using the options -I (include), -L(lib_path) and -l(library)
>> but the following message appear
>> ld: cannot find -ltestLib
>> Shall i use different options? How you tried to do it in a
>> different way?
>> Thanks
>> Luca
>> rtems-users mailing list
>> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20131001/f2e227c4/attachment.html>
