shared library with rtems
Wed Oct 2 10:57:56 UTC 2013
Check that the symbols are in your shared library file, for example with:
sparc-rtems4.11-nm libmyLib.a > symbols.txt
and then look in symbols.txt. The error indicates the library is not
being loaded correctly at link time.
-Gedare
On Wed, Oct 2, 2013 at 5:37 AM, Luca Cinquepalmi
<cinquepalmi at planetek.it> wrote:
> Now I'm able to integrate my shared libraries,
> but the compiler is not able to find the funcions implemented
> in it:
> OBSW_Xmain.cc:(.text+0x68): undefined reference to
> `HWDRV_Driver::addCanDevice(HWDRV_Device)'
> I don't think to add cpp soruce file... Can you please tell me what is the
> problem?
> I just included header files...
> Thanks
> Luca
> Il 01/10/2013 14:41, Luca Cinquepalmi ha scritto:
> Shall I use -B instead of -L option in compiling?
> Il 01/10/2013 13:36, Wendell Silva ha scritto:
> Well, it should work...
> Could you, please, post the entire command line? The lower case L ('l')
> sounds very simililar to upper case "i" ('I').
> 2013/10/1 Luca Cinquepalmi <cinquepalmi at planetek.it>
>> Yes, sure!
>> Il 01/10/2013 13:15, Wendell Silva ha scritto:
>> Is there a file named libtestLib.a in lib_path?
>>> Hi all,
>>> I'm trying to compile a shared library with sparc-rtems-gcc,
>>> by using the options -I (include), -L(lib_path) and -l(library)
>>> but the following message appear
>>> ld: cannot find -ltestLib
>>> Shall i use different options? How you tried to do it in a different way?
>>> Thanks
>>> Luca
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
