no rule to make all
dave daveerickson at shaw.ca
Sun Oct 13 19:18:30 UTC 2013
ok sure:
here is the pc-386 configure only:
[dave at localhost build-i386]$ ../rtems/configure --target=i386-rtems4.11
--enable-posix --enable-networking --prefix=/opt/rtems-4.11
--enable-cxx --enable-bsp="pc386"
configure still works...then it still fails:
target architecture: i386.
available BSPs: pc386 pc486 pc586-sse pc586 pc686 pcp4.
'gmake all' will build the following BSPs: pc386 pc486 pc586-sse pc586
pc686 pcp4.
other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
config.status: creating Makefile
[dave at localhost build-i386]$ gmake RTEMS_BSP="pc386"
Making all in tools/build
gmake[1]: Entering directory `/home/dave/src/RTEMS/build-i386/tools/build'
gmake  all-am
gmake[2]: Entering directory `/home/dave/src/RTEMS/build-i386/tools/build'
gmake[2]: Leaving directory `/home/dave/src/RTEMS/build-i386/tools/build'
gmake[1]: Leaving directory `/home/dave/src/RTEMS/build-i386/tools/build'
Making all in tools/cpu
gmake[1]: Entering directory `/home/dave/src/RTEMS/build-i386/tools/cpu'
Making all in generic
`/home/dave/src/RTEMS/build-i386/tools/cpu/generic'
gmake[2]: Nothing to be done for `all'.
gmake[2]: Entering directory `/home/dave/src/RTEMS/build-i386/tools/cpu'
gmake[2]: Nothing to be done for `all-am'.
gmake[2]: Leaving directory `/home/dave/src/RTEMS/build-i386/tools/cpu'
gmake[1]: Leaving directory `/home/dave/src/RTEMS/build-i386/tools/cpu'
Making all in testsuites/tools
`/home/dave/src/RTEMS/build-i386/testsuites/tools'
`/home/dave/src/RTEMS/build-i386/testsuites/tools/generic'
Making all in i386-rtems4.11/c
`/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c'
Making all in .
Making all in pc386
`/home/dave/src/RTEMS/build-i386/i386-rtems4.11/c/pc386'
gmake[2]: *** No rule to make target `all'.  Stop.
gmake[1]: *** [all-recursive] Error 1
gmake: *** [all-recursive] Error 1
On 10/13/2013 11:03 AM, Joel Sherrill wrote:
> Hmm.. Can you provide the configure command?
> And if you don't want to build all bsps in an architecture add --enable-rtemsbsp=xxx where xxx is the single bsp you care about.
> And it was expected the RTEMS x86 executable didn't run on Linux. It assumes bare hardware.
> --joel
> dave <daveerickson at shaw.ca> wrote:
> Ok thank you,
> So a native GCC compiler version must be a dependency?  You are right, I
> installed gcc only and it worked to configure;  then I tried to make: it
> says no rule to make all:
> configure: creating ./config.status
> pc686 pcp4.
> [dave at localhost build-i386]$ gmake all
> gmake  all-am
> Making all in .
> Making all in pc386
> On 10/12/2013 03:59 PM, Joel Sherrill wrote:
>> The configure didn't find the native GCC. Maybe you messed your PATH up adding the RTEMS tools. Or it isn't installed.
>> This is what a call to i386-rtems-4.11-gcc looks like:
>> [dave at localhost build-i386]$ i386-rtems4.11-gcc -v
>> Using built-in specs.
>> COLLECT_GCC=i386-rtems4.11-gcc
>> COLLECT_LTO_WRAPPER=/opt/rtems-4.11/libexec/gcc/i386-rtems4.11/4.8.0/lto-wrapper
>> Target: i386-rtems4.11
>> Configured with: ../gcc-4.8.0/configure --prefix=/opt/rtems-4.11
>> --bindir=/opt/rtems-4.11/bin --exec_prefix=/opt/rtems-4.11
>> --includedir=/opt/rtems-4.11/include --libdir=/opt/rtems-4.11/lib
>> --libexecdir=/opt/rtems-4.11/libexec --mandir=/opt/rtems-4.11/share/man
>> --infodir=/opt/rtems-4.11/share/info --datadir=/opt/rtems-4.11/share
>> --build=x86_64-redhat-linux-gnu --host=x86_64-redhat-linux-gnu
>> --target=i386-rtems4.11 --disable-libstdcxx-pch --with-gnu-as
>> --with-gnu-ld --verbose --with-newlib --with-system-zlib --disable-nls
>> --without-included-gettext --disable-win32-registry
>> --enable-version-specific-runtime-libs --enable-threads --disable-lto
>> --disable-plugin --enable-newlib-io-c99-formats --enable-newlib-iconv
>> --enable-languages=c,c++
>> Thread model: rtems
>> gcc version 4.8.0 20130322 (RTEMS
>> gcc-4.8.0-4.fc19/newlib-1.20.0-25.fc19) (GCC)
>> and I did the f.c test and it compiled although I couldn't get it to run
>> on my x86_64 machine.
>> Thanks,
>> Dave
>> On 10/12/2013 02:24 PM, dave wrote:
>>> Hi
>>> This is what /opt/rtems-4.11 looks like:
>>> [dave at localhost build-i386]$ ls /opt/rtems-4.11/bin
>>> aclocal                      powerpc-rtems4.11-gcc-4.8.0
>>> aclocal-1.13                 powerpc-rtems4.11-gcc-ar
>>> autoconf                     powerpc-rtems4.11-gcc-nm
>>> autoheader                   powerpc-rtems4.11-gcc-ranlib
>>> autom4te                     powerpc-rtems4.11-gcov
>>> automake                     powerpc-rtems4.11-gdb
>>> automake-1.13                powerpc-rtems4.11-gprof
>>> autoreconf                   powerpc-rtems4.11-ld
>>> autoscan                     powerpc-rtems4.11-ld.bfd
>>> autoupdate                   powerpc-rtems4.11-nm
>>> i386-rtems4.11-addr2line     powerpc-rtems4.11-objcopy
>>> i386-rtems4.11-ar            powerpc-rtems4.11-objdump
>>> i386-rtems4.11-as            powerpc-rtems4.11-ranlib
>>> i386-rtems4.11-c++           powerpc-rtems4.11-readelf
>>> i386-rtems4.11-c++filt       powerpc-rtems4.11-run
>>> i386-rtems4.11-cpp           powerpc-rtems4.11-size
>>> i386-rtems4.11-elfedit       powerpc-rtems4.11-strings
>>> i386-rtems4.11-g++           powerpc-rtems4.11-strip
>>> i386-rtems4.11-gcc           sh-rtems4.11-addr2line
>>> i386-rtems4.11-gcc-4.8.0     sh-rtems4.11-ar
>>> i386-rtems4.11-gcc-ar        sh-rtems4.11-as
>>> i386-rtems4.11-gcc-nm        sh-rtems4.11-c++
>>> i386-rtems4.11-gcc-ranlib    sh-rtems4.11-c++filt
>>> i386-rtems4.11-gcov          sh-rtems4.11-cpp
>>> i386-rtems4.11-gdb           sh-rtems4.11-elfedit
>>> i386-rtems4.11-gprof         sh-rtems4.11-g++
>>> i386-rtems4.11-ld            sh-rtems4.11-gcc
>>> i386-rtems4.11-ld.bfd        sh-rtems4.11-gcc-4.8.0
>>> i386-rtems4.11-nm            sh-rtems4.11-gcc-ar
>>> i386-rtems4.11-objcopy       sh-rtems4.11-gcc-nm
>>> i386-rtems4.11-objdump       sh-rtems4.11-gcc-ranlib
>>> i386-rtems4.11-ranlib        sh-rtems4.11-gcov
>>> i386-rtems4.11-readelf       sh-rtems4.11-gdb
>>> i386-rtems4.11-size          sh-rtems4.11-gprof
>>> i386-rtems4.11-strings       sh-rtems4.11-ld
>>> i386-rtems4.11-strip         sh-rtems4.11-ld.bfd
>>> ifnames                      sh-rtems4.11-nm
>>> powerpc-rtems4.11-addr2line  sh-rtems4.11-objcopy
>>> powerpc-rtems4.11-ar         sh-rtems4.11-objdump
>>> powerpc-rtems4.11-as         sh-rtems4.11-ranlib
>>> powerpc-rtems4.11-c++        sh-rtems4.11-readelf
>>> powerpc-rtems4.11-c++filt    sh-rtems4.11-run
>>> powerpc-rtems4.11-cpp        sh-rtems4.11-size
>>> powerpc-rtems4.11-elfedit    sh-rtems4.11-strings
>>> powerpc-rtems4.11-g++        sh-rtems4.11-strip
>>> I think I have all the right tools...I have used RTEMS before, I took
>>> the course form Dr. Sherrill.
>>> Thanks,
>>> Dave
>>> On 10/12/2013 11:28 AM, Gedare Bloom wrote:
>>>> Dave,
>>>> It looks like you don't have a host C compiler. Try installing gcc.
>>>> -Gedare
>>>> On Sat, Oct 12, 2013 at 12:52 PM, dave <daveerickson at shaw.ca> wrote:
>>>>> Ok bootstrap completed, I created a fresh directory and started a
>>>>> configure:
>>>>> According to the Getting Started manual, the --target=i386-rtems4.11
>>>>> According to the rtems/c/TOOL_TARGETS  the targets is called i386-rtems
>>>>> I tried several versions of  i386-rtems  i386-rtems4.11 i386-rtems-4.11
>>>>> and this is the compiler fail:
>>>>> --enable-posix --enable-networking --disable-cxx
>>>>> --enable-rtemsbsp="pc386"
>>>>> checking for gmake... gmake
>>>>> checking for RTEMS Version... 4.10.99.0
>>>>> checking build system type... x86_64-unknown-linux-gnu
>>>>> checking host system type... x86_64-unknown-linux-gnu
>>>>> checking target system type... i386-pc-rtems4.11
>>>>> checking for a BSD-compatible install... /usr/bin/install -c
>>>>> checking whether build environment is sane... yes
>>>>> checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
>>>>> checking for gawk... gawk
>>>>> checking whether gmake sets $(MAKE)... yes
>>>>> checking whether gmake supports nested variables... yes
>>>>> checking whether to enable maintainer-specific portions of
>>>>> Makefiles... no
>>>>> checking that generated files are newer than configure... done
>>>>> configure: configuring in ./tools/build
>>>>> configure: running /bin/sh '../../../rtems/tools/build/configure'
>>>>> '--prefix=/opt/rtems-4.11' '--host=x86_64-unknown-linux-gnu'
>>>>> '--build=x86_64-unknown-linux-gnu'  '--enable-posix'
>>>>> '--enable-networking'
>>>>> '--disable-cxx' '--enable-rtemsbsp=pc386' '--target=i386-rtems4.11'
>>>>> '--cache-file=/dev/null' '--srcdir=../../../rtems/tools/build'
>>>>> Makefiles... no
>>>>> checking for x86_64-unknown-linux-gnu-gcc... no
>>>>> checking for gcc... no
>>>>> checking for x86_64-unknown-linux-gnu-cc... no
>>>>> checking for cc... no
>>>>> checking for x86_64-unknown-linux-gnu-cl.exe... no
>>>>> checking for cl.exe... no
>>>>> configure: error: in `/home/dave/src/RTEMS/build-i386/tools/build':
>>>>> configure: error: no acceptable C compiler found in $PATH
>>>>> See `config.log' for more details
>>>>> configure: error: /bin/sh '../../../rtems/tools/build/configure'
>>>>> failed for
>>>>> tools/build
>>>>> Here is my path
>>>>> [dave at localhost build-i386]$ echo $PATH
>>>>> /opt/rtems-4.11/i386-rtems4.11:/opt/rtems-4.11/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/home/dave/.local/bin:/home/dave/bin
>>>>> On 10/12/2013 03:21 AM, Ralf Corsepius wrote:
>>>>>> On 10/12/2013 05:31 AM, dave wrote:
>>>>>>> Hello;
>>>>>>> I switched to Fedora 19 from Ubuntu and loaded all build tools and
>>>>>>> the
>>>>>>> loaded git source.
>>>>>>> I ran the bootstrap and got then got this error:
>>>>>>> ./bootstrap
>>>>>>> Can't locate Thread/Queue.pm in @INC (@INC contains:
>>>>>>> /opt/rtems-4.11/share/automake-1.13 /usr/local/lib64/perl5
>>>>>>> /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl
>>>>>>> /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at
>>>>>>> /opt/rtems-4.11/bin/automake line 140.
>>>>>>> BEGIN failed--compilation aborted at /opt/rtems-4.11/bin/automake
>>>>>>> line
>>>>>>> 143.
>>>>>>> autoreconf: automake failed with exit status: 2
>>>>>>> grep: Makefile.in: No such file or directory
>>>>>>> ./testsuites/libtests
>>>>>> Definitely a packaging bug. I don't know the cause, yet - To be
>>>>>> investigated.
>>>>>> In the meantime, try
>>>>>> # yum install 'perl(Thread::Queue)'
>>>>>> Ralf
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
