Rtems #define CONFIGURE_MICROSECONDS_PER_TICK
Oscar Siby
sibyo at student.chalmers.se
Wed Oct 16 09:33:19 UTC 2013
Hi,
Im working with a xilinx virtex 5 board running a leon 3 core,my rtems
version is 4.10.0 built from source.
My predicament is that when i change the CONFIGURE_MICROSECONDS_PER_TICK it
does not seem to change anything, here is the code of two of my tasks.
rtems_task High_task(rtems_task_argument argument)
(void) rtems_semaphore_obtain(
Semaphore_id,
RTEMS_DEFAULT_OPTIONS,
0xffffffff
end_time = benchmark_timer_read();
put_time(
"rtems_clock_tick",
end_time,
1,
0,
CALLING_OVERHEAD_CLOCK_TICK
rtems_task_delete( RTEMS_SELF );
rtems_task Low_task(rtems_task_argument argument)
benchmark_timer_initialize();
(void) rtems_semaphore_release(Semaphore_id);
puts( "*** END OF TEST 25 ***" );
rtems_test_exit( 0 );
I have tried with all kinds of values for CONFIGURE_MICROSECONDS_PER_TICK
but the put_time values is still always in the same range. Is the
benchmark_timer running on a different timer/clock ?
/Oscar
URL: <http://lists.rtems.org/pipermail/users/attachments/20131016/bc58f82d/attachment.html>
