Source builder and the Mac
sarraciro sarraciro at yahoo.it
Fri Oct 18 08:28:11 UTC 2013
You can check the Alan Coudmore teach note.. and my post in his page...
(popovich) ...
http://alanstechnotes.blogspot.it/2013/03/setting-up-rtems-development.html
Il giorno gio, 17/10/2013 alle 22.07 -0600, Andrei Chichak ha scritto:
> I've been setting up rems 4.11 for arm on a Mac that hasn't had much
> installed previously. I'm following the instructions in source-builder
> to put it all together.
> First, I grabbed the current Xcode and installed the command line
> tools.
> When I ran sb-check, it choked on cvs not existing, so I used macports
> which picked up CVS 1.11.23. On my MacBook, where things were going a
> bit more smoothly, somehow I picked up CVS 1.12.13.
> Things continue slightly better but sb-set-builder starts putting
> things together and then the "doit" command bombs somewhere in the
> bowels of config.status executing default commands.
> After much messing around I start to suspect that Xcode 5.0 isn't
> supporting some of the command line tools that are expected.
> I uninstall Xcode 5.0 and find out how to remove the command line
> tools, get rid of cvs, figure out how to download and install Xcode
> 4.6.3, reinstall the command line tools, and RTEMS starts building
> properly (openocd too!).
> So, apparently Xcode 5.0 is not compatible with source-builder for
> Mac.
> Thanks,
> Andrei
> Andrei Chichak
> Systems Developer
> CBF Systems Inc.
> 4-038 NINT INNOVATION CENTRE
> 11421 SASKATCHEWAN DRIVE
> EDMONTON, ALBERTA
> T6G 2M9
> CANADA
> Phone: 780-628-2072
> Skype: andrei.chichak
> rtems-users mailing list
> rtems-users at rtems.org
