Source builder mingw32 fails in gdb
gds gds at chartertn.net
Mon Oct 28 22:43:57 UTC 2013
On 10/28/2013 04:32 PM, Chris Johns wrote:
> Does 4.11 for MinGW32 build ok ?
Once I figured out how to go around the firewall here and do the cvs
checkout on "Sept-2013" newlib (set env. var. CVSROOT) I thought it was
going to work. However, my old version of mingw32 on fedora f14 seg
faults when compiling gcc/var-tracking.c:
../../gcc-4.8.1/gcc/var-tracking.c: In function 'void
add_stores(rtx_def*, const rtx_def*, void*)':
../../gcc-4.8.1/gcc/var-tracking.c:5782:1: internal compiler error:
Segmentation fault
$ i686-pc-mingw32-g++ --version
i686-pc-mingw32-g++ (GCC) 4.5.0 20100414 (Fedora MinGW 4.5.0-1.fc14)
(Yes, it is using g++ to compile this.)
I will try this on the f16 version of i686-pc-mingw32-g++ later.
One other thing that I've seen is that you have to have python-devel
installed. Without this, the gdb build also fails. This isn't found by
the source-builder/sb-check.
It appears all "gdb configure" is looking for is Python.h but the error
it prints sound like you don't have python installed, or that you have
the wrong version.
-gene
