Source builder mingw32 fails in gdb
Tue Oct 29 03:27:16 UTC 2013
On 29/10/2013 1:48 pm, Gene Smith wrote:
> On 10/28/2013 04:32 PM, Chris Johns wrote:
>> Does 4.11 for MinGW32 build ok ?
>> Chris
> Not much luck with 4.11 on f16 with mingw32 either. It does get past the
> gcc/newlib build with no segfaults. However, still fails on gdb for 2
> reasons.
> The first is that "gdb configure" can't find expat. I had to install the
> mingw32 version of expat even though it appears to be built by the tool
> at the start.
There should be a cross-compiled version of expat which means the paths
are not working. Hmm.
I also pushed a change the other day related to library paths to fix
building on MacOS Maverick. I wonder if I have broken something.
> After that gdb configure still fails the same way as 4.10 on f14 and f16
> in that it can't find run.exe:
> make[3]: Entering directory
> `/home/gene/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gdb-7.6-1/build-cxc/sim/arm'
> /bin/sh ../../../gdb-7.6/sim/arm/../../mkinstalldirs
> /home/gene/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems4.11-gdb-7.6-1-root-gene/home/gene/development/rtems/4.11/bin
> mkdir -p --
> /home/gene/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems4.11-gdb-7.6-1-root-gene/home/gene/development/rtems/4.11/lib
> n=`echo run | sed 's&^&arm-rtems4.11-&'`; \
> /usr/bin/install -c run.exe
> /home/gene/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems4.11-gdb-7.6-1-root-gene/home/gene/development/rtems/4.11/bin/$n.exe
> /usr/bin/install: cannot stat `run.exe': No such file or directory
This one is strange. I will see if I can reproduce the issue on an RTEMS
Fedora machine. I do not build on Fedora often and I have not built
MinGW tools on it.
