shared library with rtems
Wendell Silva silvawp at gmail.com
Tue Oct 1 11:36:23 UTC 2013
Well, it should work...
Could you, please, post the entire command line? The lower case L ('l')
sounds very simililar to upper case "i" ('I').
2013/10/1 Luca Cinquepalmi <cinquepalmi at planetek.it>
>  Yes, sure!
> Il 01/10/2013 13:15, Wendell Silva ha scritto:
> Is there a file named libtestLib.a in lib_path?
>> Hi all,
>> I'm trying to compile a shared library with sparc-rtems-gcc,
>> by using the options -I (include), -L(lib_path) and -l(library)
>> but the following message appear
>> ld: cannot find -ltestLib
>> Shall i use different options? How you tried to do it in a different way?
>> Thanks
>> Luca
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20131001/a8965763/attachment-0001.html>
