rtems_tarfs_load("/", ...) -> null_op_mknod()
Gedare Bloom
gedare at rtems.org
Wed Oct 9 02:45:48 UTC 2013
Propagating the error is the right thing to do. The application should
check for errors. I don't know that you could add much more other than
making the error code more sensible to decode. Glad you fixed it for
yourself.
-Gedare
On Tue, Oct 8, 2013 at 10:22 PM, Nick Withers <nick.withers at anu.edu.au> wrote:
> On Tue, 2013-10-08 at 20:22 -0500, Joel Sherrill wrote:
>> Could this have been detected and reported better?
> Sure - it could detect directories called (e.g.) "." and "/" and skip
> through them...
> But should it? It now does return an error in this event. If that'd been
> the case when I'd knocked my code up earlier then it would have been
> brought to my attention.
> If you don't think it's just a case of "application developer did the
> wrong thing and is now warned so it's their responsibility", I could
> knock up a patch, though?
> Nick Withers
> Embedded Systems Programmer
> Room 2.26, Building 57
> Department of Nuclear Physics
> Research School of Physics and Engineering
> The Australian National University (CRICOS: 00120C)
> eMail: nick.withers at anu.edu.au
> Phone: +61 2 6125 2091
> Mobile: +61 414 397 446
>> 'Twas my bad: I'd done my tar-ing strangely in a Makefile and had a "."
>> directory in the top-level.
>> Thanks guys, sorry for the noise!
>> Nick Withers
>> On Wed, 2013-10-02 at 13:46 -0400, Gedare Bloom wrote:
>> > Joel, perhaps the patch I checked in propagated a bad return value
>> > that was previously ignored?
>> > -Gedare
>> > On Wed, Oct 2, 2013 at 11:22 AM, Joel Sherrill
>> > <joel.sherrill at oarcorp.com> wrote:
>> > > I assume this worked in the past but what root filesystem do you
>> > > have configured?
>> > > On 10/2/2013 5:52 AM, Gedare Bloom wrote:
>> > >> Nick,
>> > >> It sounds like a bug somewhere to me. If you have a simple example
>> > >> that reproduces this behavior, could you file a report on the RTEMS
>> > >> bugzilla?
>> > >> -Gedare
>> > >> On Wed, Oct 2, 2013 at 2:46 AM, Nick Withers <nick.withers at anu.edu.au>
>> > >> wrote:
>> > >>> Hey guys,
>> > >>> http://git.rtems.org/rtems/commit/?id=97ae1eeb38a6521cfd52171cf6b816bdebf59f6b
>> > >>> seems to have broken rtems_tarfs_load("/", ...) for me.
>> > >>> rtems_filesystem_mknod() ends up calling null_op_mknod(), which
>> > >>> unconditionally returns -1 (which makes sense, given its name) and now
>> > >>> the whole shebang fails.
>> > >>> Am I doing something silly? I've really just mimicked some of the
>> > >>> examples' usage, and it works a charm with the change backed out.
>> > >>> Nick Withers
