stress program in RTEMS
Sebastian Huber
Thu Oct 24 07:17:39 UTC 2013
On 2013-10-23 19:38, Joel Sherrill wrote:
> + the Classic API did not check for NULL parameters. This
> was per the original specification and was by design. 0x0000
> was a valid address on some targets at that point in history.
> We added NULL checks in response.
So this is the reason for all these superfluous NULL pointer checks. I would
move all these NULL pointer checks under RTEMS_DEBUG and use an assert.
Applications that pass NULL pointers around also don't check for return values.
A NULL pointer check is only justified if you use a function that could return one.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
