STM32F4 discovery makefile
sarraciro sarraciro at yahoo.it
Fri Oct 25 19:21:11 UTC 2013
Hi, I've built with success a template for the stm32f4-discovery.
Now I want integrate the GPIO support (for starting) .
I've noticed :
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/stm32f4
Then I made this structure: two directories inc & src
|-- init.c
|-- lib
|   |-- inc
|   |   |-- bsp.h
|   |   |-- bspopts.h
|   |   |-- i2c.h
|   |   |-- io.h
|   |   |-- irq.h
|   |   |-- rcc.h
|   |   |-- stm32f4.h
|   |   |-- stm32f4xxxx_gpio.h
|   |   |-- stm32f4xxxx_rcc.h
|   |   |-- stm32_i2c.h
|   |   |-- stm32_usart.h
|   |   `-- usart.h
|   |-- Makefile
|   `-- src
|       |-- console-config.c
|       |-- i2c.c
|       |-- i2c-config.c
|       `-- usart.c
|-- Makefile
|-- pmacros.h
|-- system.h
|-- init.c
|-- lib
|   |-- inc
|   |   |-- bsp.h
|   |   |-- bspopts.h
|   |   |-- i2c.h
|   |   |-- io.h
|   |   |-- irq.h
|   |   |-- rcc.h
|   |   |-- stm32f4.h
|   |   |-- stm32_i2c.h
|   |   |-- stm32_usart.h
|   |   `-- usart.h
|   |-- Makefile
|   `-- src
|       |-- console-config.c
|       |-- i2c.c
|       |-- i2c-config.c
|       `-- usart.c
|-- Makefile
|-- pmacros.h
|-- system.h
but how to  the control of building-process can flow through from the
first makefile to the second one (lib/) for build the library? there 're
any recommendations to build & include a library?
Regards
SC
Il giorno mer, 23/10/2013 alle 21.34 -0500, Joel Sherrill ha scritto:
> Are you building inside the tree or outside?
> If outside, how do you build the rest of your application?
> The got module examples-v2 has working examples of the type of make files you are talking about but you are under no obligation to use them.
> sarraciro <sarraciro at yahoo.it> wrote:
> I found (docs-> /rtems/bsps/4.11/share/rtems4.11/make/Template) a README
> that explains howto write the makefile,
> I don't understand where I have to set RTEMS_MAKEFILE_PATH...
> However AlanC don't set this variable (I not saw it until now) in his
> example...
> seems that there are several ways to build with a makefile...
> The documentation talks about leaf node  Makefile and Makefile for
> directory.
> But both include Makefile.inc  or/and leaf.cfg (bsps support I
> presume)....
> I'm confused about it ... I never used them until now ... can anyone
> explain me what is the advised method and how to move on??
> Regards
> SC
> Il giorno mer, 23/10/2013 alle 13.55 +0200, sarraciro ha scritto:
> > Hi all,
> > I'm working on makefile to build custom application for
> > stm32f4-discovery.
> > The flags that I think are needed are:
> >  #include $(RTEMS_ROOT)/make/custom/default.cfg
> > RTEMS_CPU = arm
> > CPU_CFLAGS= -march=arm7-m -mthumb
> > CFLAGS_OPTIMIZE_V = -O2 -g
> > That not match the flags that I  that I used to building fw for STM32F4
> > without rtems:
> > CFLAGS  = -g -O2 -Wall -Tstm32_flash.ld
> > CFLAGS += -mlittle-endian -mthumb -mcpu=cortex-m4 -mthumb-interwork
> > CFLAGS += -mfloat-abi=soft -mfpu=fpv4-sp-d16
> > Another important  thing is (imho) add to source files the
> > startup_stm32f4xx.s file
> > SRCS += lib/startup_stm32f4xx.s # add startup file to build
> > I'm starting from AlanC makefile for RasPi...
> > I'm a bit confused right now... AlanC don't use the SRCS and CFLAGS
> > environment variables to build OBJS.... and I'm loosing in the Makefile
> > documentation...
> > Can anyone explain how to go on? or  provide a makefile for example?
> > I attach  the makefiles that I would merge in some (right) way.
> > Regards
> > SC
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
Type: application/gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20131025/83fe73c5/attachment-0001.bin>
