Source builder mingw32 fails in gdb
Mon Oct 28 20:32:01 UTC 2013
On 29/10/2013 2:23 am, gds wrote:
> I have been able run the builder OK as a native build on fedora for
> rtems 4.10 and 4.11.
Nice.
> However, when I attempt to build using ming32 on
> fedora I see this error (it can't find run.exe):
> make[3]: Entering directory
> `/home/gene/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.10-gdb-7.3.1-1/build-cxc/sim/arm'
> /bin/sh ../../../gdb-7.3.1/sim/arm/../../mkinstalldirs
> /home/gene/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems4.10-gdb-7.3.1-1-root-gene/home/gene/development/rtems/4.10/bin
> mkdir -p --
> /home/gene/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems4.10-gdb-7.3.1-1-root-gene/home/gene/development/rtems/4.10/lib
> n=`echo run | sed 's&^&arm-rtems4.10-&'`; \
> /usr/bin/install -c run.exe
> /home/gene/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems4.10-gdb-7.3.1-1-root-gene/home/gene/development/rtems/4.10/bin/$n.exe
> /usr/bin/install: cannot stat `run.exe': No such file or directory
> uname -a
> 2.6.35.14-106.fc14.x86_64 #1 SMP Wed Nov 23 13:07:52 UTC 2011 x86_64
> x86_64 x86_64 GNU/Linux
> I have run also on newer fc16 and see the same error.
> Here's the command line I use to run the builder:
> ../source-builder/sb-set-builder --host=i686-pc-mingw32
> --log=l-mingw32-4.10-arm.txt --prefix=/home/gene/development/rtems/4.10
> 4.10/rtems-arm
> Anyone seen this error and know what the problem is?
I have not been building 4.10 for MinGW32. I will have to take a look. I
suspect I have been making changes in the 4.11 configs and I have not
ported them back to 4.10.
Does 4.11 for MinGW32 build ok ?
