Source builder mingw32 fails in gdb
Gene Smith gds at chartertn.net
Tue Oct 29 02:48:31 UTC 2013
On 10/28/2013 04:32 PM, Chris Johns wrote:
> Does 4.11 for MinGW32 build ok ?
> Chris
Not much luck with 4.11 on f16 with mingw32 either. It does get past the
gcc/newlib build with no segfaults. However, still fails on gdb for 2
reasons.
The first is that "gdb configure" can't find expat. I had to install the
mingw32 version of expat even though it appears to be built by the tool
at the start.
After that gdb configure still fails the same way as 4.10 on f14 and f16
in that it can't find run.exe:
make[3]: Entering directory
`/home/gene/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems4.11-gdb-7.6-1/build-cxc/sim/arm'
/bin/sh ../../../gdb-7.6/sim/arm/../../mkinstalldirs
/home/gene/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems4.11-gdb-7.6-1-root-gene/home/gene/development/rtems/4.11/bin
mkdir -p --
/home/gene/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems4.11-gdb-7.6-1-root-gene/home/gene/development/rtems/4.11/lib
n=`echo run | sed 's&^&arm-rtems4.11-&'`; \
/usr/bin/install -c run.exe
/home/gene/development/rtems/src/rtems-source-builder/rtems/build/tmp/arm-rtems4.11-gdb-7.6-1-root-gene/home/gene/development/rtems/4.11/bin/$n.exe
/usr/bin/install: cannot stat `run.exe': No such file or directory
-gene
