STM32F4 discovery makefile
sarraciro sarraciro at yahoo.it
Thu Oct 31 18:11:45 UTC 2013
In effect...
I've tried to build the example-v2... with success.
I think that, studying them with care, I may to be able to extract the
needed information to centre the target.
Thank you
RC
Il giorno gio, 31/10/2013 alle 09.20 -0400, Gedare Bloom ha scritto:
> You can see an example of using plain Makefile in
> http://git.rtems.org/examples-v2/ I think this repo uses the
> "RTEMS_MAKEFILE_PATH" environment variable.
> You can use autotools for your application if you think the complexity
> is needed. For a simple application, copying the example Makefiles
> should work well enough. You should verify you can build the
> examples-v2 samples and run them before you try your custom code.
> I think just using Makefile is going to be simpler to follow. You
> should start by getting the examples working.
> -Gedare
> On Tue, Oct 29, 2013 at 10:07 PM, sarraciro <sarraciro at yahoo.it> wrote:
> > Hi,
> > in this days I studied about autotools.... for try to understand how to
> > build a RTEMS  application for STM32F4-Discovery out of the RTEMS tree.
> > Supposing that the location of the structure reside in
> > $(HOME)/rtems/apps,
> > a minimal structure like this:
> > apps/template$:cd testprjct && tree -L 2 .
> > testprjct
> > |--m4
> > |--builddir
> > |--Makefile.am
> > |--configure.ac
> > |--src
> > |   |--Makefile.am
> > |   |--init.c
> > |   |--inc
> > |        |-- system.h
> > |--lib
> > |   |--Makefile.am
> > |   |--minefiles.c
> > |   |--minefiles.h
> > |--README
> > 1.  It is sufficient in your opinion to guarantee the correct building
> > process of the template?
> > 2. This approach (by autotools) is the "suggested way" or the best way
> > is continuing to try with classic (write by hand) Makefile? I  thought
> > that the autotools approach could be interesting?
> > I don't have a strong know-how in software-engineering thus I think the
> > simpler approach is the more suitable for me.
> > Regards
> > RC
> > Il giorno sab, 26/10/2013 alle 19.39 +0200, sarraciro ha scritto:
> >> Yes, Later I noticed that I've already saw it... (in git repository...
> >> in fact.. :) ).
> >> I've created the directories structure in the home directory!
> >> First I want to learn to build  a RTEMS application.
> >> Regards
> >> SC
> >> Il giorno sab, 26/10/2013 alle 15.49 +0200, Sebastian Huber ha scritto:
> >> > On 10/25/2013 09:21 PM, sarraciro wrote:
> >> > > Hi, I've built with success a template for the stm32f4-discovery.
> >> > > Now I want integrate the GPIO support (for starting) .
> >> > > I've noticed :
> >> > > http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/stm32f4
> >> > This is the BSP source directory for the STM32 Cortex-M controllers.
> >> > > Then I made this structure: two directories inc & src
> >> > > |-- init.c
> >> > > |-- lib
> >> > > |   |-- inc
> >> > > |   |   |-- bsp.h
> >> > > |   |   |-- bspopts.h
> >> > > |   |   |-- i2c.h
> >> > > |   |   |-- io.h
> >> > > |   |   |-- irq.h
> >> > > |   |   |-- rcc.h
> >> > > |   |   |-- stm32f4.h
> >> > > |   |   |-- stm32f4xxxx_gpio.h
> >> > > |   |   |-- stm32f4xxxx_rcc.h
> >> > > |   |   |-- stm32_i2c.h
> >> > > |   |   |-- stm32_usart.h
> >> > > |   |   `-- usart.h
> >> > > |   |-- Makefile
> >> > > |   `-- src
> >> > > |       |-- console-config.c
> >> > > |       |-- i2c.c
> >> > > |       |-- i2c-config.c
> >> > > |       `-- usart.c
> >> > > |-- Makefile
> >> > > |-- pmacros.h
> >> > > |-- system.h
> >> > > |-- init.c
> >> > > |-- lib
> >> > > |   |-- inc
> >> > > |   |   |-- bsp.h
> >> > > |   |   |-- bspopts.h
> >> > > |   |   |-- i2c.h
> >> > > |   |   |-- io.h
> >> > > |   |   |-- irq.h
> >> > > |   |   |-- rcc.h
> >> > > |   |   |-- stm32f4.h
> >> > > |   |   |-- stm32_i2c.h
> >> > > |   |   |-- stm32_usart.h
> >> > > |   |   `-- usart.h
> >> > > |   |-- Makefile
> >> > > |   `-- src
> >> > > |       |-- console-config.c
> >> > > |       |-- i2c.c
> >> > > |       |-- i2c-config.c
> >> > > |       `-- usart.c
> >> > > |-- Makefile
> >> > > |-- pmacros.h
> >> > > |-- system.h
> >> > > but how to  the control of building-process can flow through from the
> >> > > first makefile to the second one (lib/) for build the library? there 're
> >> > > any recommendations to build & include a library?
> >> > Where do you have this directory layout?  Do you want to develop a RTEMS
> >> > application or do you want to enhance the BSP?
> >> _______________________________________________
> >> rtems-users mailing list
> >> rtems-users at rtems.org
> >> http://www.rtems.org/mailman/listinfo/rtems-users
