Source Builder failure on Ubuntu.
Karel Gardas karel.gardas at centrum.cz
Sun Sep 1 19:51:13 UTC 2013
Hi Ritesh,
err, AMD64 means this runs on 64bit OS. Error logs? I've just included
tail of build-log.txt and thought including whole error log will not
pass in as this is ~62MB text file...
Anyway, the error message is:
error: downloading
http://ftp.rtems.org/ftp/pub/rtems/4.11/rtems-4.11.tar.bz2
git://git.rtems.org/rtems.git?reset=hard?pull: all paths have failed,
giving up
I hope this is more clearer now. If not, please let me know what exactly
you need. Also please let me know if you really require whole log so
I'll try to find some place to put it on-line.
Thanks!
Karel
On 09/ 1/13 07:10 PM, Ritesh Harjani wrote:
> Hi Karel,
> I am not sure, what error you got while following Alan's blog as you
> didnt mention the build failure logs.
> Could you please tell the host machine configuration. Is it 64 or
> 32bit?? Also, the error log.
> Thanks
> Ritesh
> On Sun, Sep 1, 2013 at 10:17 PM, Karel Gardas <karel.gardas at centrum.cz
> <mailto:karel.gardas at centrum.cz>> wrote:
>     Hello,
>     I'm trying to use source builder on ubuntu 12.04 AMD64, but the
>     build process fails with:
>     prep: arm-rtems4.11-kernel-4.11-1: %setup -q -c -n
>     arm-rtems4.11-kernel-4.11-1-4.__11
>     making dir:
>     /home/karel/development/rtems/__rtems-source-builder/rtems/__sources
>     download:
>     http://ftp.rtems.org/ftp/pub/__rtems/4.11/rtems-4.11.tar.bz2
>     <http://ftp.rtems.org/ftp/pub/rtems/4.11/rtems-4.11.tar.bz2>
>     git://git.rtems.org/rtems.git?__reset=hard?pull
>     <http://git.rtems.org/rtems.git?reset=hard?pull> ->
>     sources/rtems.git?reset=hard?__pull
>     download:
>     <http://git.rtems.org/rtems.git?reset=hard?pull>: error: <urlopen
>     error no host given>
>     Build Set: Time 0:24:09.458279
>     error: downloading
>     <http://git.rtems.org/rtems.git?reset=hard?pull>: all paths have
>     failed, giving up
>     this happen twice from two attempts so I guess this is not temporal
>     ftp server problem but probably more solid issue.
>     To invoke source-builder I've followed information given by Alan on
>     his blog here:
>     http://alanstechnotes.__blogspot.cz/2013/03/setting-__up-rtems-development.html
>     <http://alanstechnotes.blogspot.cz/2013/03/setting-up-rtems-development.html>
>     -- the step:
>     4. Build and install the toolchain
>     $ cd $HOME/development/rtems/rtems-__source-builder/rtems
>     $ ../source-builder/sb-set-__builder \
>               --log=build-log.txt \
>               --prefix=$HOME/development/__rtems/compiler/4.11 \
>                4.11/rtems-arm
>     is what fails here.
>     My question is: is there something I've done wrong or is it known
>     issue in source-builder or on ftp server?
>     Thanks!
>     Karel
>     _________________________________________________
>     rtems-users mailing list
>     rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     http://www.rtems.org/mailman/__listinfo/rtems-users
>     <http://www.rtems.org/mailman/listinfo/rtems-users>
