Source Builder failure on Ubuntu.
Sun Sep 1 22:00:32 UTC 2013
Karel Gardas wrote:
> Hello,
> I'm trying to use source builder on ubuntu 12.04 AMD64, but the build
> process fails with:
> prep: arm-rtems4.11-kernel-4.11-1: %setup -q -c -n
> arm-rtems4.11-kernel-4.11-1-4.11
> making dir:
> /home/karel/development/rtems/rtems-source-builder/rtems/sources
> download: http://ftp.rtems.org/ftp/pub/rtems/4.11/rtems-4.11.tar.bz2
> git://git.rtems.org/rtems.git?reset=hard?pull ->
> sources/rtems.git?reset=hard?pull
> git://git.rtems.org/rtems.git?reset=hard?pull: error: <urlopen error no
> host given>
> Build Set: Time 0:24:09.458279
> error: downloading
> git://git.rtems.org/rtems.git?reset=hard?pull: all paths have failed,
> giving up
> this happen twice from two attempts so I guess this is not temporal ftp
> server problem but probably more solid issue.
> To invoke source-builder I've followed information given by Alan on his
> blog here:
> http://alanstechnotes.blogspot.cz/2013/03/setting-up-rtems-development.html
> -- the step:
> 4. Build and install the toolchain
> $ cd $HOME/development/rtems/rtems-source-builder/rtems
> $ ../source-builder/sb-set-builder \
> --log=build-log.txt \
> --prefix=$HOME/development/rtems/compiler/4.11 \
> 4.11/rtems-arm
> is what fails here.
> My question is: is there something I've done wrong or is it known issue
> in source-builder or on ftp server?
Nothing you have done and I can confirm it is a bug in the RSB. I am
currently working on this. It is related to the addition of
--without-rtems. This broke the "with" RTEMS. As a work around please
add --without-rtems to the command line.
I expect to have a fix soon.
