lm3s8962 was Re: Contact - RTEMS tests
Thu Sep 19 11:27:47 UTC 2013
Hello Karel,
if you like, you can update the RTEMS 4.11 release notes:
http://www.rtems.org/wiki/index.php/4.11_Release_Notes#BSPs_and_Device_Drivers
On 2013-09-18 22:29, Karel Gardas wrote:
> Hi,
> supported stellaris socs are: lm3s6965, lm3s3749 and lm4f120. Anyway, lm3s8962
> looks like a fury class that means the most similar should be lm3s6965.
> Creating BSP for this means really just a bit of hacking in
> c/src/lib/libbsp/arm/lm3s69xx -- configure.ac, custom cfg, linkcmds (here
> lm3s6965 looks like the same), and various C files. The advantage of current
> multi-family stellaris BSP is that you will get nice #error message on
> compilation and will know exactly where to touch code in order to add proper
> support. Usually adding just SOC #ifdef if the feature is supported is enough
> to get it going...
> IMHO it should be less work than what I did for LM4F120 since this was more
> different from LM3x than LM3S8962 looks and even for LM4 the work was really
> minimal...
> Cheers,
> Karel
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
