rtems-hello-multiple baudrate problem
Fri Sep 20 10:01:14 UTC 2013
On 2013-09-20 11:26, Sarkrass - wrote:
> We have compiled the rtems-hello-multiple.c example, with the RTEMS 4.10
> version, and succesfully upload it to the AT697 board installed in a RASTA 101
> system.
> The example sets the serial port baud rate to the default value (38400 bps);
> we tried to set the baud rate to any other value, the example is compiled
> without errors, but the modifications are not performed: the messages are
> received in the console to 38400 bps.
> Could anyone help us with this problem?
I would figure out if the console driver supports setting of attributes.  You
can use a debugger to verify that you end up in the drivers set attributes
function.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
